It is currently Sun Jun 07, 2026 10:24 pm
 Post subject: missfiring...
PostPosted: Tue Oct 05, 2004 5:44 pm
Alrighty, my luv is still missfiring. When i run it realy hard (mostly hill climbing and mudding) it starts acting like the carb is loading up (lack of power hesitaion and back firing). Now it dosnt do it all the time so its probly not the carb, but i tuned it anyway. New air cleaner and i just replaced the coil. This would leave plugs wires rotor and cap that still need replacing. Could it be in one of those? Also bear in mind its an 82 ignition and a webber carb. Anyone have any ideas i should pursue?
PostPosted: Tue Oct 05, 2004 7:50 pm
When you're pushing it, your generating more heat than normal, and transistorized system are really susceptible to heat problems. Have you another control module to try?
PostPosted: Tue Oct 05, 2004 9:12 pm
Yep, electrical systems do not like heat. Does it only do it when the engine is warm, or does it do it no matter how warm the engine is?
PostPosted: Tue Oct 05, 2004 9:20 pm
I will be watching this post to see what his problem turns out to be, because i have just the opposite prob w my truck. Now that it's getting cold outside my truck is a sluggish dog and belching back thru the carb for 1st ten mins on the road each mrning, then once I'm up to 55, it runs fine and faster i go the better it does, but this 1st thing stuff that's going on w it....well i'm about to give it a swift kick in the pants! :lol:
bear in mind that this is a BRAND NEW engine installed in May this yr, only has 6,000 miles on it right now, and EVERYthing there was brand new as well......am confused here. :?
PostPosted: Wed Oct 06, 2004 4:23 pm
it only happens when the motor is running at operating temp (i have only ever seen it hit 190*). I did plugs wires cap and rotor today and the problem was still there (though i did pull out one vary nice carbon fouled plug). So i ran some carb cleaner down it and played whith the mixture and idle some and it seems to be idling a whole bunch better now. Ill see if it runs better tonight when i go to my brothers house.
PostPosted: Wed Oct 06, 2004 4:25 pm
lil blue what carb are running? Becouse i know whithg my webber its vary tempermantal in the cold. If i romp on it when its still cold it will make a bad sucking sound and then i have had it die. That or all of a sudden it will catch up and ill roasting the tires... :lol:
PostPosted: Wed Oct 06, 2004 6:19 pm
Luvtruck.com Wookie
did that tune up solve your problems?if not you might want to make sure that your adapter plate for the weber is tight ..... i have to tighten mine down about once a month and it does the same thing when it's a little loose.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Wed Oct 06, 2004 6:21 pm
alrighty ill check that if i still have the problem. But right now it seems like its going perty good, but that is just idling and revving it in the shop...
PostPosted: Wed Oct 06, 2004 10:29 pm
I am running a stock Hitachi carb, that rebuilt same time engine was
PostPosted: Fri Oct 08, 2004 10:28 am
well my truck is running fine now. Lil blue you might just try playing whith the adjustment on the carb and looking for any cracked vac lines and such. Also a crack phenolic spacer might do it too.
PostPosted: Fri Oct 08, 2004 8:54 pm
Okay, thanks for the tip there, really appreciate that. :wink:
I haven't had time to even raise the hood, much less look it over.Everyday, it's jus run run run and get the cars to get this wrecking yard into full swing soon as i can 8O
But hopefully the smoke will clear soon, and then i can examine it closely. meanwhile i have no choice but jus put up w it. Gave it a good swift kick in the pants, but accomplished nothing but hurting my foot LOL :lol:
