It is currently Mon Jun 29, 2026 11:37 pm
PostPosted: Thu Dec 19, 2002 6:36 pm
If everything works out RATNLUV will be on the scales Sat. and I will post the weight on each wheel and total.Going to be using a set of dirt track scales. Also picking up license plate RATNLUV next week. Hard to imagine that no one else in Tennessee had used that one! :lol:
stripped and just a memory!
PostPosted: Thu Dec 19, 2002 6:52 pm
i thought you had the plate :?
PostPosted: Thu Dec 19, 2002 7:02 pm
I have a plate that looks like a real one made at a rod run several years ago and it was on it until I registered it and started driving it.
But this is the real Mcoy.
PostPosted: Sat Dec 21, 2002 12:25 pm
LF 783.5 RF 793
LR 622 RR 596
TOTAL 2794.5 WITHOUT DRIVER big block & Iron heads
for a comparrison we also weighed a 80 mustang 302 Aluminum heads
LF 734 RF 752.5
LR 632 RR 643.5
Total 2762 Without driver
PostPosted: Sat Dec 21, 2002 8:10 pm
that's what mine weighs well almost 2780 without driver ,small block ,steel heads ,9", no cage
PostPosted: Sat Dec 21, 2002 8:12 pm
Can someone tell me why a couple of topics, like this one, come up with the page too big. the words go way past the edge of the screen, i have to scroll over and back to read.
can i click a dang button to releive myself of this overwhelming burdin.
:snipersmile: (overwhelming burdin)
PostPosted: Sat Dec 21, 2002 8:13 pm
that last post is mine,i forgot to log in :x
PostPosted: Sat Dec 21, 2002 8:34 pm
i think it b/c of the pic, so its my bad :oops: ill edit my post to fix it
PostPosted: Sat Dec 21, 2002 11:08 pm
2762 us small block guys should be about 160lbs lighter if my figures are correct. does yours still have the heater box and wiper assembly? i figure i could shed a few pounds that way.
PostPosted: Sun Dec 22, 2002 7:45 am
No heater, wipers, dash , roll bar, inner fenders and just a shell of a bed.I have been looking at heater boxes but I want A/C also and may be going with a aftermarket unit. As for wipers I am looking at street rod type again limited space and I just look at the weather before I drive it for now. I am sort of in the research and development stages.
Everything is going to have to come back apart later for final work on frame and firewall. For now I am putting miles on it and seeing if there is anything that needs changing before final painting of frame.
Roll bar will depend on ET in the spring.I am not sure if I am going to go to the trouble but probably will. Jegs offers one so it's not a big deal.
As rough as this truck is it still gets noticed and as I said before I am NOT building a race truck I am building a DRIVER and I am sure it will be over 3000 lbs. before it is over but thet is still less than a lot of vehicles.
Air conditioning is a must for me. I want to ride on hot days with the windows up.Several companys make very compact unit so again it is a matter of saving the bucks for it.
I started this truck last year around Aug.and it was complete with a 350 and turbo 400 and have put over 800 miles on the big block in the last few months.
Also planning on power windows(some neat kits are out there now)and maybe a digital dash setup.Check out some street rod magazines for ideas.
I consider the hard part is over it is running and dependable.I am going to put the fuse box and relays behind the seat.And get the dash put in and keep adding options as fund allow.
And last but not least just remember If I add to much weight with all the old man,fat boy comfort options a 427,454 or 502 is a bolt in swap.
502/502hp would be nice!
PostPosted: Sun Dec 22, 2002 1:48 pm
thanx larphead!
ratnluv- keep us (me) posted on your AC install. I'd like to throw one in this spring, but would like to do it cheap!
Users browsing this forum: Bing [Bot] and 20 guests
