It is currently Sun Nov 09, 2025 10:59 pm
 Post subject: Tie rod ends
PostPosted: Fri Jun 25, 2004 8:37 pm
Where can I get the tie rod ends for my 79 luv 2wd. none of the parts stores can get them, so they say,I would think that would be easy to get (a part that wheres out easy). Or is there one that i can use from another truck?
PostPosted: Sat Jun 26, 2004 8:55 pm
ya can get em in oz :D
PostPosted: Sun Jun 27, 2004 1:28 am
I just looked them up at http://www.autozone.com . Im not sure if they list them correctly. The outer rods would be different from the inner rod ends. If all else fails, go to NAPA.
PostPosted: Sun Jun 27, 2004 3:07 am
i dont know how a 79 luv would be set up but on my 73, theres only the 1 type of tie rod end, however there is a similar one called a side rod
 Post subject: Tie Rod Ends
PostPosted: Sun Jun 27, 2004 11:50 am
I went to Autozone, Napa, Schucks and Kneckts they all said we can order it but when they tried they said it was discontinued. So I pulled one off an 80'luv in a yard. They look simple to make, square tube bar stock thread the ends and get normal tie rod ends for each side. I now have my old one to use as a guide. (I didn’t know that there is no tie rod ends its all one peace with the ball joints pressed into each end). Thanks for the help.
PostPosted: Sun Jun 27, 2004 6:24 pm
thats the side rod, they do have tie rods, on the steering linkage
PostPosted: Wed Sep 29, 2004 8:29 pm
I just ordered some tierod ends for my 80 Luv 4x4
I still have to take the old ones off. does anyone know if they have
reverse threads. My dad had new supsension for his Ford Hot Rod and the drivers side has revserse thread for the tie rods.
8)
PostPosted: Thu Sep 30, 2004 12:02 pm
Zane,
Tell us wehere you ordered them from.
PostPosted: Thu Sep 30, 2004 2:51 pm
Yes, one side has right handed threads and the other has left handed threads. When you unthread the ends, make a note of the number of threads (full turns) that it takes to remove them. Thread the new ones the same number and lock it in place. This will be close enough so you can drive the truck to an alignment shop.
PostPosted: Thu Sep 30, 2004 10:21 pm
TruckLuVer wrote:
Zane,
First I orded the inner Tie rods and I acutally though the inner
were the part that connect the tie rod and the idler arm and pitmarn arm.
The inner are the connected to the Tie rod ends.
I am ordeing them from Napa. I am not suprised if the drivers side will be reverse thread. [url]From http://www.napaonline.com[/url] I am trying to order the Idler arm Bushing.
Users browsing this forum: Bing [Bot] and 39 guests
