It is currently Mon Jun 15, 2026 2:51 am
 Post subject: holley help please
PostPosted: Sun Sep 12, 2004 8:24 pm
new at hotrods..i got a 850 dual feed holley.like i said rookie.been trying to get info off the net.ok what are the two screws small tiny screws on each side of the carb and what do they do and how many turn and the angle one on the right ide what is it called and do rookie help thanks :oops:
PostPosted: Mon Sep 13, 2004 6:31 pm
somebody help this guy.................................geesh.........i might later bro..gimme some time........
434 pushing 732 hp with no spray!!!
PostPosted: Thu Sep 23, 2004 2:07 pm
i think your talking about the float screws.... you remove the big screw above it while its at idle and adjust little screw til fuel just starts to leak out then your floats are set. replace big screw and your ready to go :wink:
http://bonsaint.com/luvalbum2/index.htm
more pics of my 76 406ci 4 spd posi.
PostPosted: Thu Sep 23, 2004 7:12 pm
Wrong.....
The little screws on either side are for your idle mixture ONLY. if you try to set them with it idled up to high your waisting your time. set the idle speed low then adjust them. normally 1 3/4 to 2 turns out is a good starting place. back them out till it runs rough then turn them in till it runs rough. then get right in the middle for a happy camper.
Wabbit he did say he was new to this .... take a chill pill and relax man we can coach him into a great bench racer LOL
GOTTA GET A NEW LUV!!!!!!!!!
PostPosted: Fri Sep 24, 2004 9:36 pm
Spanky wrote:
Wrong.....
There are 2 right. One on each side. So, do one at a time I would think? I am in need of my holley to be tuned up as well.
PostPosted: Sat Sep 25, 2004 6:01 am
yes there is 1 per side unless you got a 4 corner idle ( unlikely ). useually you can run it out of the box with a few minor adjustments. Idle and such
PostPosted: Sat Sep 25, 2004 9:25 am
http://chevyhiperformance.com/howto/45638/
Here's a link that might help you out some.
