It is currently Mon Jun 08, 2026 5:25 am
 Post subject: Bad news turned good!
PostPosted: Fri Sep 10, 2004 7:47 am
The engine started knocking this weekend when I went to drive the luv. I can't tell if it is the top end or the bottom end. When I listen to it from the top it sounds like the top end. When listening from the bottom sounds like from the bottom end. When I listen from the grill, it sounds like it is outside of the engine bay in front of the radiator. Sounds like its in real pain.
Haven't really taken a hard look at it yet. Haven't been able to get up the nerve.
PostPosted: Fri Sep 10, 2004 12:02 pm
PostPosted: Fri Sep 10, 2004 4:59 pm
Resident Sparktrician
The longer you wait, the worse it could be. Go for it brutha!
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
PostPosted: Sat Sep 11, 2004 2:42 am
yea....what he said. If it just started knocking, the block might be salvageable (if it is the pistons). My buddies Chevy dually diesel started knocking about a year and a half ago and now the cylander wall is ovaled. so a $500 in gaskets, pistons, and having the block bored, Just turned into a $8,000 new engine............................DON'T wait to fix it if at possible
If everybody grows up with high self-esteem, who is going to dance in our strip clubs?
What's going to happen to our porno industry?
These women don't just grown on trees.
PostPosted: Sun Sep 19, 2004 1:40 am
one way you cud try and find the prob is to wet n dry compression test it, thats if ya have access to one
PostPosted: Thu Sep 23, 2004 8:18 pm
if its a 2wd then its easy to pull the oil pan... i would pull it and inspect for problems. all you've got to do is pull the brace under then engine and drop the pan. an in frame rebuiild is pretty easy.
PostPosted: Wed Oct 06, 2004 7:45 am
Not sure whether I should feel stupid, or be happy. Figured out what the problem was yesterday. My alternator was only hanging on by the adjustment bolt. Therefore it was rattling. Sounded awful. Ran a solid bolt through the bottom and all is good now.
I guess the original bolt(s) had shaken themselves loose. I don't know if any of you guys remember some of my previous posts when I was having all those electrical problems after going off-roading. Think a loose alternator might have been the culpret.
PostPosted: Wed Oct 06, 2004 8:58 am
phew not engine prob's at least well and you fixed another problem at it as well way to go 8)
PostPosted: Wed Oct 06, 2004 4:29 pm
kick ass 8)
