It is currently Mon May 25, 2026 4:54 pm
 Post subject: Fuel filler hose
PostPosted: Fri Sep 10, 2004 11:30 am
Banishment Pending
Well, when i was putting on my lift(an ongoing process it seems) I found that when i went in to add the extension to the fuel filler hose( the one that goes from the side of the bed to the gas tank) that the hose was all rotted out, which would explain the gas smell. My question is can i use a radiator hose, or a flexable radiator hose in place of the filler hose ( i'm asking so that i don't have to buy a new one and cut it up to put the spacer in, truth be told i'd like to forget the spacer all togather if it's posible!) well if any one can give some info on this i would be very graitful,
TJ
PostPosted: Sat Sep 11, 2004 6:04 am
I used a radiator hose on my boat. and never had any trouble.
PostPosted: Sun Sep 12, 2004 11:21 pm
Banishment Pending
Thanks i'll go ahead and try it, if it doesn't work then ohwell, a new one for me then, thanks
