It is currently Fri Jul 03, 2026 12:05 am
PostPosted: Fri Sep 03, 2004 10:56 pm
im doin a head job on a 93 ford escort. The book says to toss the old bolts and get new ones. Well i didnt toss the old ones and its probably a good thing because I have called every auto parts store in town and the ford dealership and none of them supply the bolts anymore. Any ideas? Will the old ones work?
PostPosted: Sat Sep 04, 2004 12:09 am
yes they will still work.......alot of manufactures say to replace the head bolts b/c they are designed to streach after you torque them down. therefore not giving a absloute correct torque reading next time.
but i have reused them before w/ no problems......admittely never on a escort tho
PostPosted: Tue Sep 07, 2004 4:19 am
well today i finally did the head job on my car. The machine shop had to take about 15 thousands off it...is that a lot? After getting everthing back together and putting the valve cover on i realized how much the head had actually warped...the valve cover does sort of a teeter totter thing now if the bolts arent in. Anyways, i finally got it to fire up but it now immediately dies after starting it. Also it sounds really loud like an exhaust leak. Maybe i didnt tighten the manifold down hard enough on the new gasket? I didnt use the torque specs for the manifolds but im pretty sure i got it fairly close. There was no way i was gonna fit the torque wrench in such tite places...any ideas?
Users browsing this forum: Baidu [Spider] and 7 guests
