It is currently Tue Jun 30, 2026 5:58 am
 Post subject: I need a rearend expert!
PostPosted: Sun Dec 15, 2002 1:20 am
I need to find an axle expert because of a problem im having with my setup. I typed out info on MS notepad so i could e-mail it to whomever can help. Im not very fast at typing and this way i can try to be as clear as i can with my problem. So if anyone can assist me, please send me an e-mail and i can respond with an attachment. My address is chevyluv76522@yahoo.com . Thanks...John
PostPosted: Sun Dec 15, 2002 2:26 am
I have a buddy that does all of our axles. "Our" being me and my friends. He's not all that computer savy so it might be hard to hook you guys up. I don't even think he has an email address right now.
If at first you don't succeed, try it like your wife told you to do it.
PostPosted: Mon Dec 23, 2002 3:05 pm
A couple of people have got me wise to the fact that ineed to fix the pinion alignment to match the trans output shaft alignment. i figure there's a 7.5 degree misalignment between the two. So its all going to be reworked. Total rebuild! I'll post the outcome when im done. Thank you everyone....John
 Post subject: pinion angle
PostPosted: Tue Dec 24, 2002 2:18 pm
Japanese Redneck
is that 7.5 degrees of NEGATIVE angle? I purposely dial in a few extra negative pinion angle (about 5 total) . Truck launches a LOT harder. but theres a oscilating vibration when you cruise the highway. Old school secrets.
PostPosted: Tue Dec 31, 2002 7:04 pm
The trans output shaft angles downward @ 2.5 degrees and the pinion centerline angles downward @ 5 degrees. As for an ocilation, V-6 motors have an inherent ocilation. I really dont mind it. If i feel it going down the Hwy, then i know everything is smooth with the engine. If the ocilation isn't noticable, then the motor has a problem.
