It is currently Fri Mar 27, 2026 6:07 pm
 Post subject: Rocker Panels
PostPosted: Sun Dec 01, 2002 8:07 pm
Does anyone know where I could find some rocker panels??
PostPosted: Sun Dec 01, 2002 8:16 pm
I think that's going to as hard as finding a dash!!! When I had mine relpaced 14 years ago, we had to order them from Isuzu in Japan!! Took about 2 weeks to get them. Don't want to bum you out but I had a hard time find them back in 88. Try an Isuzu dealer, I think that would be the best place to start.
PostPosted: Sun Dec 01, 2002 8:42 pm
i had planned on making my own outta sheet metal. my guard unit just got a new electronic sheet metal brake that im just diein to play with 8)
 Post subject: rocker panels
PostPosted: Tue Dec 10, 2002 11:36 pm
just had all body work and paint done had to make one rocker panel
could not find one anywhere.
PostPosted: Wed Dec 11, 2002 8:38 pm
how much did making one run you back?
PostPosted: Thu Dec 12, 2002 9:16 am
I bought both sides about four years ago from a body and fender place in Hagerstown- he had them on the shelf. I think they were around $20. each. They are kinda cheesy- more like the "screw over top of the old ones to get thru inspection " variety, but they are roughly the right shape, and with a little work, fit pretty good. I just got around to doing the passenger side last week- I'll soon have some photos posted. The inner sill panels you're going to have to make, but they're pretty flat, and easy to peice together if you don't have a brake- the hardest part of the whole project is that if the outer rocker is gone, all the stuff inside that ties the door sill together with the cab mounts (the flat part of the door sill runs all the way from the front of the cab to the back) is probably gone, too. I had to make all that, as well- fabbing the peices isn't bad, but the cleanup work is a real bear. The name of the body and fender place is Christy Enterprises-301.791.2522 I've got a call in now, and the guy is looking into seeing if he can still get them...
steve
PostPosted: Mon Dec 16, 2002 7:33 am
I just got a call back from Russ at Christy Enterprises (301.791.2522)- he said they can still get LUV rocker panels for both sides- they're $26.60 each.
steve
PostPosted: Mon Dec 16, 2002 11:41 am
good work!!!!!!
03Cobra
PostPosted: Thu Dec 19, 2002 7:39 pm
thanks alot, man thats pretty damn cheap!
 Post subject: rocker panles
PostPosted: Sat Jun 07, 2003 11:58 pm
You can get rocker panles from exoticwooddash.com (109.00) for chrome. :D
PostPosted: Sun Jun 08, 2003 7:08 am
I did a search and found a place called Smeals Enterprises. They list them on their web page for $20. Also try Pacific Automotive Warehouse web site.
Users browsing this forum: No registered users and 119 guests
