It is currently Sat May 09, 2026 4:26 am
 Post subject: timing markes
PostPosted: Wed Dec 11, 2002 7:54 pm
Are my timing markes on the crank gear and the cam gear supose to face each other?
I rebuilt the motor and head put it all back together I took all the smog crap off and changed points and now it back fires through the carb when it's idling. it's 1.8 thanks
PostPosted: Wed Dec 11, 2002 8:02 pm
if its like the timing on my 1.8 (1980) the mark on the crank points a a sliver link on the chain and the mark on the cam points at another silver link, its a bitch to time :x
also its a "interferance" eng meaning if it get too far outta time or the chain breaks and the crank keeps turning it will bend the valves w/ the pistons. this is what happened to me, chain broke, bent the valves, so now is time for a v6 :D
hope this helps
PostPosted: Wed Dec 11, 2002 9:00 pm
Thanks for the advice I'll try to restab and take another look at the chain and see if i need to reajust my valves.
PostPosted: Thu Dec 12, 2002 12:52 am
i just rebuilt mine about 2 months ago and ran into the same problem.check the timing on your distributer .i have no clue on how to fix this exept to turn your dis. i watched my dad do it to mine and the backfiring stoped emediatly
