It is currently Tue Mar 31, 2026 12:55 am
 Post subject: Want to lower front end
PostPosted: Tue Aug 03, 2004 1:48 pm
I have a '72 W/ front disc upgrade. How do you lower the front end?
PostPosted: Tue Aug 03, 2004 4:12 pm
The torsion bar adjusters are located on the transmission crossmember. Jack the front of the truck up in the air first before making any adjustments. To lower the ride height, loosen the adjuster bolts evenly on both sides of the truck. Make sure that your not riding on the bump stops.
