It is currently Sun Jun 07, 2026 10:40 pm
 Post subject: LUV with S-10 Parts
PostPosted: Wed Jul 28, 2004 3:47 pm
Will the 4.3 liter V6 engine along with the manual 5 speed tranny from a S-10 fit into a 1980 LUV. If so what things do I need to convert it. And also will the 4WD system out of the S-10 fit into the LUV?
PostPosted: Wed Jul 28, 2004 5:44 pm
Look at the V8 swap article in the information section of the main luvtruck.com site. A 4.3 shares a lot of characteristics with a V8 so that should give you some idea of what you are getting into. Just about any swap will require some of the same steps.
The 4WD system has a lot of "depends" in the answer. I don't know which side the front drive line comes out on the S10, but that is an issue only if you are keeping the stock LUV front axle. LUVs have the front diff on the left, but some trucks have it more to the right. You need a straight line from the transfer case front output to the differential. If you put a solid axle under the front end, you just need to pick something the matches the engine and transfer case you are dealing with. So it depends a lot on what else you are doing with the truck. Anything will fit if you do enough fabrication work, but some things fit with a lot less work than others. I think I'd do some looking at 4.3L swaps that people are doing on other rigs, especially Isuzu Troopers/Amigos/Rodeos and see what barriers they found and how they overcame them. http://www.4x4wire.com is a good place to look for Isuzu info, especially the TrailTalk BBS forums there.
PostPosted: Sun Aug 01, 2004 12:10 pm
i'm almost certain that s10s have their front driveshaft on the drivers side, so a solid front axle would have to be swapped in.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Sun Aug 01, 2004 8:36 pm
THANKS FOR THE INFO FROM BOTH OF YOU
Users browsing this forum: Baidu [Spider] and 27 guests
