It is currently Sat Jun 13, 2026 8:46 am
 Post subject: 4wd into 2wd????????
PostPosted: Mon Jul 26, 2004 7:56 pm
used to live at Luvtruck.com
Is it possible to change a 4wd into a 2wd? What all is involved in the swap? I am planning on getting new front suspension anyways, so is the rest the same as the 2wd? Has anyone done this before? Thanks,
Jess
I got my LUV!!!!!!!
PostPosted: Tue Jul 27, 2004 12:56 am
did you buy a 4x4? I must of missed something :?
PostPosted: Tue Jul 27, 2004 7:13 am
no I saw one the other day though, and was wondering if it's possible and if so, how much work is involved. anyone know?!?!?!
I got my LUV!!!!!!!
PostPosted: Tue Jul 27, 2004 8:39 am
i thought you already had a 2wd luv you should have a 4wd for out in the mud or off roading dont you think
PostPosted: Tue Jul 27, 2004 9:36 am
I'd think that if i were to tackle such a mod, i'd remove everything down to the frame and install a new, aftermarket front end. Getting specific, stock front end parts will be more hassle than it's worth. And besides, if your going to put such an effort, you can eliminate the torsion bars by going with a coil-over setup.
If your set on having a stock-type, 2wd front suspension, I would then suggest that you sell/trade the truck for a 2wd. The value of a 4wd could be a benefit when working a deal.
PostPosted: Tue Jul 27, 2004 9:53 pm
yeah I've got a 2wd, and 4x4ing would be fun, but I can't really afford two running trucks. lol. :wink:
yeah I'm definitely planning on getting the mustang II front suspension anyways since stock stuff is such a hassle. BTW to anyone that has done this before or just knows: does anyone know how much the front cross member is going to be? I am paying $300 for the mustang II, is that a good deal?
What about the rear though? How are 2wd and 4wd different?
thanks
I got my LUV!!!!!!!
PostPosted: Tue Jul 27, 2004 10:39 pm
There are kits that can be had for as little as 800.00 To over 1600.00. So 300.00 for a donor seems like a good deal to me. You'll most likely need to rebuild everything all the way across (wheel bearings, ball joints and such) You should hunt down RatinLuv and ask him how he installed his Stang II clip. As for the rear axle, there's no major difference between 2 and 4wd. Just that the ratios are different (4.56 for 2wd and 4.10 for 4wd and automatics)
PostPosted: Tue Jul 27, 2004 10:44 pm
ok cool thanks!
I got my LUV!!!!!!!
PostPosted: Wed Jul 28, 2004 4:26 pm
JessMn is there a way that i could get the 4wd componets
PostPosted: Wed Jul 28, 2004 9:22 pm
if I get one, sure. As of now, I haven't bought one, I was just wondering how difficult it would be to change it.
I got my LUV!!!!!!!
Users browsing this forum: Majestic-12 [Bot] and 13 guests
