It is currently Wed Feb 11, 2026 8:42 pm
PostPosted: Mon Jul 19, 2004 12:08 am
Can someone please tell me how to lower my front suspension 1974 model luv
PostPosted: Mon Jul 19, 2004 3:58 am
easy! just adgust the torsion bars. depending on how much you want to lower it, take off the rear adjuster and rotate it a few clicks on the spline that way the bolt still sits in the same spot. (it will all make sense when you have a look at it) all the adjustmens are under the centre of the cab behind the cross member
hope this helps
PostPosted: Mon Jul 19, 2004 7:37 pm
Cheers Mate
PostPosted: Tue Jul 20, 2004 8:57 pm
Luvtruck.com Wookie
when you change the suspension gemetry that much (over an inch) you'll need to get the front end re-aligned.
hate to give ya bad news but if the handling gets all weird when u drop the front end it's acualy an easy fix.
good luck ....and how much are you trying to drop it?
TiLtEd wrote:
Boobies!!! :D
PostPosted: Tue Jul 20, 2004 10:37 pm
I've herd everyone say that you would need to get a front end alignment but I dropped mine 2.75 inches in the front and it drive perfectly straight when I let go of the wheel. Not saying that you shouldn't though.
PostPosted: Wed Jul 21, 2004 2:04 am
I also followed the repair manual's procedure for adjusting the ride height. It says to loosen the strut bars (they go from lower A-arms to the front corners of the frame) and then retorque them when finished. I did need an alignment when finished though. You might get it to track straight, but it will VERY likely wear tires funny like outside edge more than inside.
