It is currently Wed Feb 04, 2026 9:09 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: ET's????
PostPosted: Mon Dec 02, 2002 11:52 pm
Everyone Put down you ET's and what you are running.
PostPosted: Tue Dec 03, 2002 1:15 am
1/8 mile, 9.65 et
and im still waiting to get there :lol:
btw i think in my case thats 9years 6months and 5days :oops:
PostPosted: Tue Dec 03, 2002 1:41 am
60' = 1.592
1/8th = 7.436
MPH = 90.41
1/4 = 11.795
MPH = 111.23
Oops, forgot the parts list.
350Chevy, 9.5:1, TH400, 9" 4500stall, Ford 9" rear w/4.56, Victor Jr., Pro-Jection 900, MSD, DartII's, roller 236/244 w/ .560/.579, lotsa port work, Hooker LUV headers, Dual 3" pipes with 2-3" Flowmasters, stock suspension with welded on ladder bars.
If at first you don't succeed, try it like your wife told you to do it.
PostPosted: Tue Dec 03, 2002 3:34 pm
Local strip is closed the test and tune night until spring.Will let you know as soon as they open back up.The wait is killing me, :x but I will have time to get the nitrous all hooked up and working. :)
stripped and just a memory!
PostPosted: Tue Dec 03, 2002 7:12 pm
Ask this question again this spring. I cant wait to get to the track. truck is probably running 7's in the quarter..............................................................................I WISH! :lol:
PostPosted: Tue Dec 03, 2002 9:19 pm
Small block 406 with Edelbrock performer heads, 750 double pumper,570 roller, 10:1 compression, 350 turbo, 3000 stall, 3.73 gears on 28x11.50x15 Et street tires. 11.07@123mph on 89 octane. 1.55 60ft. 7.04@99mph in the 1/8. Tried the NOS on a launch and went 1.44 60ft.
Mike & Chanin Saiki
http://www.motivational.net
 Post subject: et's
PostPosted: Tue Dec 03, 2002 9:37 pm
i run a 383, 9:1 compression with stock 2.02 heads 350 trans 3000 stall , 9" ,3.89gear 28x12.50 tyre ,1/8, 8.15 et at 84.14mph 1/4 i guess
a high 12 at 105mph the only 1/4 mile track i have run on was at 5000ft and it went 13.69 at 98.8 mph
PostPosted: Fri Dec 06, 2002 6:36 pm
Hmmmm 75 bone stock STILL running the quarter I get back to you when I get there !!! :lol: :lol: :lol: :lol: :lol: :lol: :roll:
PostPosted: Fri Dec 06, 2002 9:33 pm
just an update on 12/5 i went 7.87 at 89.45mph just a little laughing gas :D
PostPosted: Sat Dec 07, 2002 9:44 am
nthe10s-
you posted that you tried the NOS on the launch. OK. did you ever run it for the whole quarter? Why not if so. what was your time. what hp were you jetted for. 8)
"G"
PostPosted: Sat Dec 07, 2002 12:40 pm
I launched it, shifted to 2nd gear and the car shut completely off! Something shorted out the ignition. It coasted through the 1/8 with a 6.68@89mph. I had this motor in my Vette that weighed 3300lbs. and it ran 9.90@138mph. The luv is 300 lbs. lighter and leaves just as hard as the Vette. The luv could easily run 9.70@140mph. i had a 150 horsepower jet in the NOS cheater plate. I have since taken the NOS off and been working on a new combo to run 10.6-10.7 on the motor on 89 octane gas. This is my girlfriends truck and it is getting too fast for a street car.
Mike & Chanin Saiki
PostPosted: Sat Dec 07, 2002 7:14 pm
Hmmm. I always thought vettes were supposed to be heavy rigs. the luv was supposed to be a small light truck. Only 300 pounds difference?!?
a couple of years ago i took a load to the dump in my "pre v8 luv" ( if only i had known) and ran it over the scales and it weighed in at what I thought was about 2200 lbs. Sounds like your saying they run about 3000 lbs. Interesting.
i know under the vettes fiber g body is supposed to be a really thick, strong, heavy frame.
I am bummed- 3000#'s is a lot of weight to push. Anyone ever get their truck weighed?
"G"
PostPosted: Sat Dec 07, 2002 7:21 pm
One more thing- why did you take the kit off.
Reason I'm asking is we hear all the warnings about N20 and I know a v8 can take an occasional shot. I have a sniper that Ive run around town for kicks- jetted at about 75 mainly. I plan to run it up to 150 ONCE this spring at the track. i'd hate to trash something though. thats why I saw your post and figured id ask.
I dont plan to run it all the time. I beleive that it is a cheap add on, although a fun one, and believe real acomplishment is to gain bigger horsepower through things like stroking and turbo charging. I plan to stroke the luv next summer :twisted:
"G"
PostPosted: Sat Dec 07, 2002 8:19 pm
At one time, mine weighed 2990 without me in it.
Since then I've probably removed about 100lbs.
3000lbs. isn't too bad for a street/strip car. My buddy has a 77 Camaro that weighs about 3750!
PostPosted: Sat Dec 07, 2002 8:35 pm
mine weighs 2780 without me in it , runing a 150 shot is fun but you said you dont want to break any thing .i would MAKE SURE that you have enough fuel pressure to go with that much n2o,i would put a fuel pressure switch on it to make sure that it does not run out of fuel pressure, if that happens that is when parts break !!!!! ask inthe10s
PostPosted: Sat Dec 07, 2002 8:44 pm
one more thing ,if you get fast enough- 7.49,1/8- 11.99,1/4 you need more safty equiment, roll bar, driving suit,stuff like that good luck
p.s. not that hard to start going that fast with a 150 shot [100 hp is about
1sec in the 1/4 mi]
PostPosted: Mon Dec 09, 2002 2:24 pm
Our truck weighs 3000lbs. with driver. We also have a roll bar, 20 gallon fuel cell, 2 batteries, 100lbs. of lead bars. I took the nitrous off because my girlfriend races the LUV. She doesn't need this much power. It runs 11.0 on motor with 89 octane fuel. It will run about 10.6-10.7 in a bit. I run nitrous on every car I own. I run a 300 horsepower unit on my Vette. You should be able to run 125-150 all day long if you have forged pistons and a decent set of rods. Retard the timing a few degrees and run good gas. Don't be greedy with nitrous!!!!!!!!!!!!!!
Mike & Chanin Saiki
PostPosted: Mon Dec 09, 2002 6:09 pm
THE DIGITAL 6 takes care of the retard nicely. 92 octane all the way. sweet.
PostPosted: Mon Dec 09, 2002 9:25 pm
This is sort of getting of the subject but in the late 80's I was running a 100 hp boost on a VW rail buggy.I used a oil pressure switch at the feul selonoid and wired it to where if the fuel pressure droped it turned the nitrous off.Just look in the parts books and they list pressures and normally closed or open.You may have to find a above average parts person because most people at parts stores now know very little.
You can buy kits to do it now .Lack of fuel pressure is probably the # 1 cause for engine failure.I also had a switch on the oil pressure and I never had any problems out of my system and loved it.
I am planning on starting with a 100 shot on the RATNLUV next spring.
But only after I see what it does on all motor first.
PostPosted: Mon Dec 09, 2002 11:16 pm
I installed an oil pressure switch on the fuel pump, I have this idea some day Ill crack the truck up somehow and the fuel pump will just keep pumping. If there was a fire..... 8O A big ol pile of charcoal would be my next stop. Nice thing about it is its right behind the distributor, so you can jump it with a screwdriver an prime the fuel system anytime you want. :wink:
thanx for the tip with the n20 , though.
"G"
