It is currently Sun Jun 28, 2026 3:31 pm
 Post subject: exhaust noise
PostPosted: Fri Dec 06, 2002 5:40 am
OG Lifer
i am havin problems again. at idle, my truck seems to have an exhaust gurgle. with the hood open, the engine runs very smoothly, (thankd to a new weber carb) and doesnt miss or run poorly. but if you go to the back of the truck, you can hear the exhaust popping and chugging. the plugs look fine, and the carb is set right, (not running rich). could this be a muffler taking a poop (the exhaust system looks old). it is not sucking and blowing like a burned valve. thanks for any help :wink:
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Fri Dec 06, 2002 5:59 am
just get going down the road reeel good then turn the truck off while still in gear.....pump the gas a few times then turn the ignition back on.......the gas will fill the exhaust and when it ignites it WILL find the weak spot in the exhaust system!!!!!! :twisted: :microwave: :onfire: :snipersmile:
pretty much all those......
03Cobra
 Post subject: Ummm...
PostPosted: Fri Dec 06, 2002 12:39 pm
Hey grimace.
Thanks for the backup on that there spellin b. As for the exaust problem I would not recommend the luv4me solution, I have met, heard and seen first hand what that little trick can do to aluminium heads ( blown head gaskets, bent valves) Anyway I would have to go with the timing it may be just a hair off and the valves hav'nt fully closed before the spark is sent. Take the muffler off the pipe and see if it still making that noise. You would be surprised how much you can learn listening to open exaust.
Hope this helps... (BTW.. no offense luv4me)
Dave
PostPosted: Fri Dec 06, 2002 12:43 pm
LOL!!!!!!!!!!
Your crazy man. :)
I bet your one of those people that puts an egg in the microwave.
If at first you don't succeed, try it like your wife told you to do it.
PostPosted: Fri Dec 06, 2002 4:54 pm
OG Lifer
luv4me. i would probably take your advise if i knew nothing about cars :lol: . no offense but man you are out there! :wink: . anyway, never thought of the open header idea. (btw no prob bout yonder spellin bee thang :D ) well im gonna try out some stuff. i think i also need to adjust the lifters as well. i have a little bit of lifter clatter. not much but a little. thanks guys. (you need professional help there luv :P )
PostPosted: Sat Dec 07, 2002 12:21 am
Egg in the microwave... that's nothing. Try putting a CD in a microwave. It is quite the show. It doesn't blow up or anything, just a small controled lightning show and fire. 8)
PostPosted: Sat Dec 07, 2002 6:41 am
OG Lifer
just like a fork brother. just like a fork :wink:
PostPosted: Mon Dec 09, 2002 6:26 am
yeah.....uh.....I guess I should have posted a reply to my solution of your problem. it was entirely meant to be funny. I would never do that to something I owned.
Have you checked the donut that connects the exhaust manifold to the exhaust pipe? it might be pulling air in there.
the warning to my reply might have been written like this.
WARNING! My previous reply was meant as a Comedic response only. DO NOT attempt without utter disrespect to your vehicle and Just downright trying to mess it up.
is that better guys??????
03Cobra
PostPosted: Mon Dec 09, 2002 9:00 pm
OG Lifer
just for the record, it was taken as a joke brother :wink: . n e way, i did check the exhaut gaskets, and i think i need to have the head re-worked. that sucks. oh well such is life. later all :D
Users browsing this forum: No registered users and 56 guests
