It is currently Thu Jul 02, 2026 5:02 am
PostPosted: Wed Jun 23, 2004 11:20 am
anybody know where you can get an aftermarket wiring harness for a 90's TBI chev v8. arizona emmissions is throwing a fit and want all the emmissions equip for the engine of same year or newer. rather than have a smog pump, and other space robbing garbage i'd like to go with a tbi engine. I'm sure the long nose water pump will cause problems but thats ok. If thats the case I'll stick the radiator in the bed.
note... if you have to go thru emissions a 74 and older is only tested on what comes out the pipe! not whats under the hood.
unfortunately mine is a '79.
suggestions??
 Post subject: One place...
PostPosted: Wed Jun 23, 2004 12:03 pm
One place that makes the harness you mention is Painless Wiring. They have the TBI standalone harness with I believe a four wire hookup. You can check their site and it will give you the computer part number you need and all that key info. You can usually order them through Autozone. I think they run around $700.
PostPosted: Wed Jun 23, 2004 12:04 pm
:lol: finally got to 35 posts... man i am out of control.. hehe
