It is currently Thu Jul 02, 2026 1:25 am
 Post subject: fuel line size
PostPosted: Fri Jun 18, 2004 10:02 pm
When I was collecting parts for my new fuel system I bought a roll of aluminum fuel line. Its 3/8ths. Is that going to be big enough to feed a stock v8? At what point do you step up to 1/2"?
PostPosted: Sat Jun 19, 2004 9:35 pm
I would think so as the factory 425 hp cars only had a 3/8 and a mechanical pump ..... some of your factory v8 cars only had a 5/16ths line ... I would run a 3/8ths though
GOTTA GET A NEW LUV!!!!!!!!!
PostPosted: Sun Jun 20, 2004 8:53 pm
Should be ok. thats what I've got on mine.
Resident lurker
PostPosted: Sun Jun 20, 2004 9:23 pm
Same here.
PostPosted: Sun Jun 20, 2004 9:54 pm
SB 400 with stock Luv fuel lines here. No signs of fuel starvation.
