It is currently Mon May 25, 2026 12:29 pm
 Post subject: Hooker Motor Mount Pics
PostPosted: Fri Jun 11, 2004 5:05 pm
Just got the hooker mounts installed.They fit real good!The motor and trans is just for mock-up.The real beast is going in soon.Going to have to make room for the blower lower pulley.See pics http://v8swaps.homestead.com/LUV.htmlI'll keep the LUV fans updated.
PostPosted: Fri Jun 11, 2004 10:45 pm
looking good keep up the good work
 Post subject: motor mounts
PostPosted: Sat Jun 12, 2004 8:26 am
Hey 6-71
First off the mounts look good.......I have a few questions about your set up. I myself an putting a 6-71 blown sbc in a luv, which is why Im asking.Where are you going to put your radiator?Are you going to run the hooker headers for the v8 luv truck?I used a front and mid plate instead of motor mounts .Had to set the engine way back so the blower belt and pulleys would clear the radiator.Of course I cut the fiirewall and floor just a bit.Well good luck and hollar if you have any questions.
Donny.................a.k.a......luvondope :drinking:
PostPosted: Sat Jun 12, 2004 2:14 pm
luvondope,
I notched and box the front cross member just a little to clear lower pulley.I didn't want to cut the firewall or trans tunnel.The lower brace in front of the radiator will need to be notched also.The radiator will fit just behind the grille.The radiator I'm using is for a R/E dragster,Griffin (JEG's)part# 475-225135-H.It is almost the same width as a stock LUV.
PostPosted: Sun Jun 13, 2004 12:01 pm
i am just wondering wher you get them hooker mounts i wants a 350 luv but dont know were to look. i would like to run a 350 with a munsi 4 spd is that a good idea or not?
kevin
PostPosted: Sun Jun 13, 2004 12:43 pm
Summit sells the kits. HOK-12606 for the SB chevy mounts. HOK- 12630 for the transmission bracket that fits the TH 350 and manuals. You can save yourself a lot of hassle if you get the header kit too. HOK- 2140
