It is currently Mon May 25, 2026 1:00 pm
 Post subject: Chopped Top Attempt
PostPosted: Thu Jun 10, 2004 10:27 am
Hello,
These trucks are not easy to chop.
Last edited by 671SuperchargedLUV on Thu Jun 10, 2004 11:10 am, edited 1 time in total.
PostPosted: Thu Jun 10, 2004 10:41 am
welcome!
why is it an attempt? lookin good to me!
03Cobra
PostPosted: Thu Jun 10, 2004 11:00 am
Thanks
Had to cut the top in 4 pieces and fill a 2" gap.This is a 4" chop.Hey,I looked at your rotor upgrade.NICE.My question is,I been thinking of putting a steering rack out of one of my Datsun 240Z parts car in my LUV.Think it would work?My Datsun drag car is at http://www.v8Swaps.com
Now that's finished it's time for the LUV
Thanks
PostPosted: Thu Jun 10, 2004 2:07 pm
looks pretty good. before you forget how you did it, make up a scale drawing (if you can) and post it, many guys that are thinking about doing that would appreciate being able to look at where to chop it... including myself.....
PostPosted: Fri Jun 11, 2004 4:51 am
671SuperchargedLUV wrote:
Thanks
Thanks
I replied to your email, but just for other people wanting to know the same thing, you may want to check out RATNLUV's pics. he has installed mustang II components and a rack in his luv.
03Cobra
PostPosted: Fri Jun 11, 2004 10:28 am
Looks good so far!!
I would love to chop mine too, but would look real stupid with my head sticking out of the roof. :D (my head touches the roof now!!)
And why does that look like you are doing that on MY FRAME???? 8O
I can't believe there are 2 pink framed Luv's still in this world!! :twisted:
PostPosted: Fri Jun 11, 2004 8:25 pm
I also like the wider rear end, reminds me of my truck..... but as of tomorrow I will have one thats only 3 inches wider than stock under it.... Its coming out of a Pontiac Ventura II...
PostPosted: Sat Jun 12, 2004 12:38 am
About installing a rack.I had a Mustang II rack that was narrowed and was made to mount to the bolt in cross member under the engine.I'm running the Hedman S10 v8 headers.I took it out and went back to the stock box.It was going to be a nightmare to hook up.I shortened a column,and it was going to take 3 u-joints a couple of shafts,a mounting bracket,and the angles weren't going to be good
PostPosted: Sat Jun 12, 2004 5:50 am
The rearend is a early 8" Ford that is 56 1/2" wide wheel flange to wheel flange.Would work good in a stock truck being it is only 1 1/2" wider per side than stock LUV rearend.The 8" will be replaced with a narrowed 9" that I have that is 39 1/4" wide.The rear frame rails have been narrowed to 24".This chopped truck will be strip only.I'm currently building one for the street also.I used a rearend out of a S10,direct bolt in.
As far as the chop,decide how much you want and take many measurements.Find a cab that you can use as donor and try it on that one first.
