It is currently Sat Dec 13, 2025 4:57 pm
 Post subject: Tools Explained
PostPosted: Fri Jun 11, 2004 5:35 pm
Here is a list of tools and their typical usage. Anyone who has spent time working on cars will be able to relate to this.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive car parts not far from the oblect we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard boxes delivered to your front door; works particularly well on boxes containing convertible tops or tonneau covers.
ELECTRIC HAND DRILL: Normally used for spinning steel pop rivets in their holes until you die of old age, but also works great for drilling rollbar mounting holes in the floor of a sports car just above the brake line that goes to the rear axle.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence it's course, the more dismal your future becomes.
VICE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intence welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting those stale garage cigarettes you keep hidden in the back of the Whitworth socket drawer(What wife would think to look in there?) because you can never remember to buy lighter fluid for the Zippo lighter you got from the PX at Fort Campbell.
ZIPPO LIGHTER: See oxyacetylene torch.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now mainly used for hiding six-month old Salems from the sort of person who would throw them away for no good reason.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against the Rolling Stones poster hanging over the bench grinder.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard earned guitar callouses in about the time it takes you to say,"Django Rienhardt".
HYDRAULIC FLOOR JACK: Used for lowering your Luv to the ground after installing a set of lowering springs, trapping the jack handle firmly under the front air dam.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a truck upward off a hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbor to see if he has another hydraulic floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayo; used mainly for getting doo-doo off your boot.
E-Z OUT BOLT AND STUD EXTRCTOR: A tool that snaps off in a bolt hole and is 10 times harder than any drill bit known to man.
TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup on crankshaft pulleys.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and hydraulic clutch lines you may have forgotten to disconnect.
CRAFTSMAN 1/2 X 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
BATTERY ELECTROLYTE TESTER: A handy tool for transfering sulfuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
AVIATION METAL SNIPS: See hacksaw
TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D,"the sunshine vitamin", which is not otherwise found under cars at night. Health benefits aside, it's main purpose is to consume 40-watt light bulbs at about the same rate that 105mm howitzer shells might be used during, say, the first few hours of the battle of the bulge. More often dark than light, it;s name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used , as the name implies, to round-out phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by a hose to a Chicago Pneumatic impact wrench that grips rusty suspension bolts last tightened 40 years ago by someone in Abingdon, Oxfordshire, and rounds them off.
:lol:
PostPosted: Fri Jun 11, 2004 6:34 pm
Luvtruck.com Wookie
ROMFLMAO.........true so true ....sad too......
you did forget wrench; a tool used as a hammer once you've busted the handle off.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sat Jun 12, 2004 9:30 am
thats good stuff
PostPosted: Sat Jun 12, 2004 3:44 pm
HAMMER...a.k.a....Hard Headed Convincing Tool and Tapometer
Funny stuff!
PostPosted: Sat Jun 12, 2004 11:18 pm
Good stuff..... Glad someone finally told me what those things were used for.... Now maybe I will start doing stuff right.....
PostPosted: Mon Jun 14, 2004 7:14 am
HAMMER (A.K.A) beatin stick
