It is currently Sat Jun 13, 2026 10:00 am
 Post subject: vin #s
PostPosted: Sun Jun 06, 2004 1:17 pm
how hard do you guys think it would be to swap the vins on my cab.... i can get the door plate off easy enough, but im wondering about what i should do with the one under the hood valance...... :?: its not that i am worried about getting pulled over for anything and havin the vins mismatch, its just that i dont want to pay for all that crap to be changed to a diff # (title, insurance, all that crud).... any ideas??????
PostPosted: Tue Jun 08, 2004 3:55 pm
I Changed the vin tag on my truck and didnt have any problems. The only tag on mine is located on the door jam. When I took it to the courthouse the lady only asked where the vin# was located at and she wrote the numbers down...The only reason I had to swap mine was because I used a cab and doors off a different truck...So you have the title in your name and tags on it?? If so i dont see any problems. Just switch em....
Kevin
PostPosted: Wed Jun 09, 2004 6:15 pm
should just be an issue of drilling out the rivets.
PostPosted: Thu Jun 10, 2004 2:20 pm
well, i can drill out the rivets fairly easily, just use a bit small enough to drill out the middle of the rivet then screw a dent puller (w/small bit) into the rivet and one good slam will yank it out.... i was just wondering about the one under the windshield valance....
PostPosted: Thu Jun 10, 2004 3:14 pm
Luvtruck.com Wookie
my 1980 doesn't have a vin under the windsheild. there is one stamped into the frame though...it's hidden by the fuel tank
TiLtEd wrote:
Boobies!!! :D
PostPosted: Thu Jun 10, 2004 6:28 pm
The one under the cowl near the windshieldis stamped into sheet metal, not a tag. Not much you could do to swap it short of a torch and weld job, or swapping cabs. It is completely covered by the cowl so I would think not much of a worry for licensing purposes. In fact, unless the cab is stolen and somebody wanted to verify, I doubt it would ever come up.
The one on the frame near the tank, is that stamping into the frame or just painted on? I've yet to run across that one and it seems like someone here was looking for another spot the VIN might be found that is permanently marked. My 79 has the remnants of the vin painted on with a stencil on the outer side of the frame rail just behind the passenger side door, but it is usually unreadable or painted over I think.
Users browsing this forum: Google [Bot] and 20 guests
