It is currently Fri May 01, 2026 4:48 pm
PostPosted: Wed Apr 14, 2004 8:37 pm
Has anyone ever tryed putting a small diesel turbocharger on a luv diesel? or is it even possiaable?
PostPosted: Tue Apr 20, 2004 8:14 am
I personally have not but would like to do that to my diesel.
PostPosted: Tue Apr 20, 2004 1:12 pm
The Isuzu pup trucks had turbos on them in 1986 and 1987. It was also an option in the later trooper IIs
1981 Chevy LUV 4x4 2.2L Diesel 4 Speed Selling out moving over to VW TDIs.
PostPosted: Wed Apr 21, 2004 7:25 am
I am going to have to look into that since I have to rebuild it anyway.....
PostPosted: Wed Apr 28, 2004 7:16 pm
What kind of turbo you think would work on that? what would you have to do? you think the compression is to high and might gernade the engine
PostPosted: Wed Apr 28, 2004 10:24 pm
diesels tend to like boost. since the fuel injectors control the timing instead of spark plugs like a gas engine, there's no such thing as preignition.
however, some diesels aren't as well built as others, but i think the isuzu engines should be able to handle some boost
PostPosted: Thu Apr 29, 2004 6:54 am
hmmmmm...have to find one then will post what i find out about it..
PostPosted: Thu Apr 29, 2004 5:38 pm
Hey Guy just wwanna thank you for given me some info... yea let me know what you find out... i dont really now alot about diesel turbos
PostPosted: Fri Apr 30, 2004 12:33 pm
Alright sure will I have to go today to go look at some turbos so will tonight...and will post what i find out
 Post subject: hey
PostPosted: Tue Jun 08, 2004 8:01 pm
hey man did you find anything about that turbo??
PostPosted: Tue Jun 08, 2004 8:39 pm
I found one or two that i can get but have to do some more research to see if they would work or not
PostPosted: Tue Jun 08, 2004 10:54 pm
The C223 diesel motor used in luvs and early Isuzus is basically the same as the C223T used in Isuzus after 85. I doubt there are really too many differences and I've heard of at least one being coverted to use the later year turbo gear. Check out the BBS/forums at http://www.4x4wire.com and look in the Isuzu section. They have a category devoted to Isuzu diesel subjects and I bet there are some gems of info in there.
PostPosted: Tue Jun 08, 2004 11:02 pm
thanks lots of great info there
PostPosted: Tue Jun 08, 2004 11:33 pm
You have to be sure to change the setting at the bottom of the Isuzu Diesel forum page to something more than "show all topics from last 2 days" in order to see it all. The diesel forum doesn't get a huge amount of traffic on a daily basis, but it is steady and there is a lot if you go back over the older posts.
This one seems to cover the turbo vs non issue well:
http://www.4x4wire.com/forums/showflat.php?Cat=&Number=374121&page=0&view=collapsed&sb=5&o=all&fpart=1
