It is currently Sun May 10, 2026 10:21 am
 Post subject: fuel cell question.....
PostPosted: Sat May 29, 2004 11:34 pm
I have just ordered a fuel cell from summit with the 0-90 sender in it. My question to you guys is what is the likly hood the oe fuel gauge in say a 82 luv or in my case an 84 pup will be compatible?
I was wondering about this not becasue I plan on using the stock gauge for long, just while my truck in under construction. I will buy a autometer electric gauge but I am not quite ready to start working on the interior of my truck quite yet.
any ideas?
if it doesn't work it is no biggie, I have only put $5.00 worth of gass in it since I have owned the truck....which has been since last summer.
Bagged 84 Pup
Bagged 53 F100
stock 72 Citroen DS19
PostPosted: Tue Jun 01, 2004 4:52 am
from what I understand, fuel senders work off of ohms....why don't you fill the original tank up with some kind of fluid and check the ohms across the connections?
03Cobra
PostPosted: Tue Jun 01, 2004 5:19 am
You don't even have to fill it with fluid. The summit tank senders are removable and work by a float pull the sender out and connect ohms meter, move the float up and down. should have a higher resistance at the top of the float and lower at the bottom. Then you know your range. All you have to do then is find out what the factory resistences are and go from there. Hope this helps?
The LUVa from down unda. CHEERS
PostPosted: Tue Jun 01, 2004 9:50 am
he knows what the summit cell is.....just not what the original is. :wink:
03Cobra
PostPosted: Tue Jun 01, 2004 7:13 pm
w3rd, yeah, I know that the summit is a 0-90 just have no idea what the stock one is....I guess I'll just hook it up and see if it will work.
Bagged 84 Pup
Bagged 53 F100
PostPosted: Wed Jun 02, 2004 5:08 am
Just told you how to check the original one. Or were you a bit slow to understand what i meant do you want me to break it down for you a bit more :roll:
PostPosted: Wed Jun 02, 2004 8:29 am
stock should be 0-2 ohms full and 135-165 ohms at empty.
Resident lurker
PostPosted: Wed Jun 02, 2004 9:43 am
LMAO
calm down mate
03Cobra
PostPosted: Wed Jun 02, 2004 4:50 pm
yeah mate, dont get your $hit hot....... My meter is a piece and only reads continuity. All of my extra cash is going into the suspension right now so I didn't want to have to go out and buy yet another tool for something I dont really even need to use (the gas gauge) right now.
And thanks to Diarmadhim we all now have an answer, thanks bro, I appreciate it!
Bagged 84 Pup
Bagged 53 F100
PostPosted: Thu Jun 03, 2004 10:35 pm
It didn't work when I tryed it on mine. I ended up using a stick to check
PostPosted: Fri Jun 04, 2004 12:42 pm
alright, cool, then I wont even mess with it. I'll wait till I get to the interior stage of my build.
Bagged 84 Pup
Bagged 53 F100
Users browsing this forum: Bing [Bot] and 14 guests
