It is currently Sun Jun 07, 2026 5:55 pm
 Post subject: runs out of gas
PostPosted: Sun May 30, 2004 8:08 pm
hi my luv just got its carb rebuilt and now it will idle but when u give it gas it dies! it runs out of gas i guess. i looked in the carb and when you give it gas nothing really comes out of the acelerater pump hole thing. i dont know how much or if any is supposed to come out but really none does. WHAT IS WRONG WITH THE LUV? please help me i have a contest at school at the end of the week and i need to be running!!!!
PostPosted: Mon May 31, 2004 7:26 am
Looks like you discovered the problem yourself. When you hit the throttle the accelerator pump should provide a stream of gas down the carb throat. This provides a smooth transistion between the idle circuit and the mains. My suggestion is to take it back to the guy who rebuilt it and have him clean and check ALL the passages and jets. If you are doing it youself , soak it over night in a good carb cleaner, blast all passage ways with compressor air or can air if you don't have a compressor. You can also use a can of GUMOUT carb cleaner clean and check the passage ways, (Watch the eyes). Don't use wire to clean the passage ways or jets you could gouge them and change the metering. Take you time and do a thorough job at each step. Good Luck
PostPosted: Tue Jun 01, 2004 2:15 pm
Ck the linkage on the carb and find the arm that pushes the diaphram on the accellerator pump. Mine was stuck in the IN mode so it shots it load of gas then was stuck in that position. I WD40 that part of the carb.
Also you can ck the diaphram also. Its EZ dude handle it!
