It is currently Sun Dec 14, 2025 3:34 pm
 Post subject: TH-350 return line
PostPosted: Sat May 22, 2004 8:42 am
I had to get a stall converter and a trans cooler for my new motor. Before I can hook up the trans cooler I need to know which line on the trans is the return line. Anyone know this off the top of your head?
PostPosted: Mon May 24, 2004 11:24 pm
waited to see if anyone responded, and you probably have figure it out by now, but I would of said the bottom one.
PostPosted: Tue May 25, 2004 8:23 am
Correct.
PostPosted: Tue May 25, 2004 7:47 pm
I haven't messed with it again yet. Took the week off from the T-bird and the Luv. I'll be back at it this weekend though.
PostPosted: Tue May 25, 2004 9:29 pm
I thought it didn't matter which one was which, you could just hook it up... :?
PostPosted: Tue May 25, 2004 10:29 pm
Its kinda like the heater hoses. The trans pumps in one direction just like a water pump. So there is a wrong and right way.
PostPosted: Wed May 26, 2004 3:06 pm
Hmm well I must have got it right when I did mine :D . Will it wreck anything if its backwards?
PostPosted: Wed May 26, 2004 9:03 pm
It wouldve already overheated and toasted the trans.
PostPosted: Wed May 26, 2004 10:10 pm
8O ...Good to know. Thanks!
