It is currently Tue Feb 03, 2026 5:30 am
 Post subject: Headers
PostPosted: Sun Nov 24, 2002 10:19 pm
What is a good cheap way to go with headers for the luv?
PostPosted: Sun Nov 24, 2002 11:05 pm
I know that Thorley makes headers for 1.8 Luv engines with all smog hookups if needed.
PostPosted: Sun Nov 24, 2002 11:18 pm
sorry i was talking about small block
Sorry about that
PostPosted: Mon Nov 25, 2002 12:51 am
For the most part, you have two options.
Change the front suspension to a coil over setup so you can remove the torsion bars and run almost any header, or pay the money for the Hooker Headers and motor mounts for the LUV V8 conversion and use the stock front end.
PostPosted: Mon Nov 25, 2002 6:04 am
I have headers and motor mounts that I am not going to use.
get in touch with me and make an offer.
all parts are brand new.
03Cobra
 Post subject: headers
PostPosted: Mon Nov 25, 2002 7:34 pm
hey man i will give you 200$ for the set of headers + everything else transmission and motor mounts
PostPosted: Mon Nov 25, 2002 7:56 pm
hey ill give you 100 for the mounts I live in marysville :o
PostPosted: Tue Nov 26, 2002 6:51 am
I have engine mounts, but no tranny mount.
I will take $200 for the headers.
who is the guest?
79luv said something about engine mounts, but didn't say how much he would give for them. let me see what he says about them and if the guest will email me I will let you know.
thanks
you can email me skyedivr@yahoo.com
03Cobra
PostPosted: Tue Nov 26, 2002 4:21 pm
yeah I will give you 200$ for headers and engine mounts do you have another way I can get a hold of you maybe the phone? my email is screwed up :x
PostPosted: Tue Nov 26, 2002 7:58 pm
On the topic of headers, does anyone have a set of headers for a 3.8/4.1 buick V-6 that they want to sell? My exhaust system is rather old, so if gotta go thru it , i might as well go thru it completely.
PostPosted: Wed Nov 27, 2002 6:19 am
try Autofab......that is where I got the headers for my previous 3.8......if they still make them.
03Cobra
PostPosted: Wed Nov 27, 2002 9:46 am
Loan me about $10,000 for about 20 years to redo my truck and I will GIVE you my chrome headers!! :D Anyway, like Luv4me said, try Autofab. That is where I got mine from also.
PostPosted: Wed Nov 27, 2002 11:21 am
Autofab wants 450.00 for the headers. I was hoping to get out a little cheaper than that. It was worth a shot.
PostPosted: Wed Nov 27, 2002 2:09 pm
dayum......I don't think I gave that much for the kit to put the V6 in mine!
you could always build your own.......they have kits......
lemme tell you though.....it is a tedious task.
03Cobra
 Post subject: If its a V-8 conversion
PostPosted: Thu Nov 28, 2002 8:39 am
Japanese Redneck
if its a V-8 conversion, you can get Hooker Super Comp V-8 conversion headers they have 1 3/4 primaries, 3 1/2 collector but I dont like them much because one tube goes on the outside of the frame and requires a slip tube fit. If hooker was smart they would have made all the tubes go on the outside of the frame... basically they should have made the LUV conversion header as a Fenderwell exit header. So anyway... what do i use? I use a Sanderson block hugger header. its pricey but its one of the only block huggers that comes in 1 3/4 primary (most come in 1 5/8")
PostPosted: Mon Dec 02, 2002 1:45 am
luv4me, your a Guru!
 Post subject: HEADERS
PostPosted: Sun Jan 05, 2003 11:50 am
I HAD HOOKER SUPERCOMP HEADERS ON MINE THAT WORKED, BUT WITH THE BLOWER MOTOR AND THE ANGLE PLUG ALUMINUM HEADS I HAD TO HAVE MY HEADERS CUSTOM BUILT.THEY ARE 2 1/8 PRIMARYS AND 3 1/2 COLLECTORS :D
PostPosted: Sat May 03, 2003 10:48 pm
I have seen a luv with s-10 shorty header and they work just fine as long as you dont move the motor back to far
PostPosted: Sat May 03, 2003 10:50 pm
I have seen a luv with s-10 shorty header and they work just fine as long as you dont move the motor back to far and they can be gotten from jeg's and just about any parts cataloge for around $100
PostPosted: Tue May 06, 2003 6:49 am
So the Hooker engine swap headers arent realy an easy bolt on type part? Did I read that right? One tube goes outside the frame? Do you have to weld these things together? I m a bit confused. I thought they were like any other header.
