It is currently Wed Jul 01, 2026 2:33 am
 Post subject: ?Electric Fuel Pump?
PostPosted: Wed May 19, 2004 7:45 pm
The Truck is a 79.
Where does it get is (+)power from??
I traced the wire and either I messed up or it comes from the (-) post on the coil.
:!: Help please :!:
PostPosted: Wed May 19, 2004 8:12 pm
There's wiring diagrams under Info on the home page of this site.
PostPosted: Wed May 19, 2004 9:58 pm
Thanks :D
PostPosted: Thu May 20, 2004 7:07 am
:!: :!: :!: HELP :!: :!: :!:
ok I got the whole tune up done, changed fuel filters and all that. got the right wires going to the right stuff. I went to crank it and there was no fuel come from the tank. I dropped the tank and found 15 years of sludge stuff to the bottom. How do I get it out cause that 2 inch hole for the sender unit just ain't workin. Should I try to find an other tank? Thanks For the help.
PostPosted: Thu May 20, 2004 10:44 am
There are companies that'll steam clean and seal your tank for you if you wanted to do that. Otherwise if you already have the tank dropped then why not get some cleaner and take a garden hose to it? If its sludge that should do it... but if its hardened stuff like rust or something then you may need to look for a tank.
PostPosted: Sun Mar 20, 2005 11:50 pm
YOu should have local companies that will steam it & seal it from the inside.....should be good as new again
PostPosted: Fri Mar 25, 2005 11:56 pm
I just got a tank sealer kit from POR15 for $54.00 It comes with a cleaner and etching acid to clean the tank before you put the sealer in. But i took mine to a car wash and cleaned 90% of the crud out of it before i used the stuff that came in the kit. My tank now looks like new inside. But i already had the bed off, so my tank was very easy to remove.
Check out POR15.COM
Ike
Only God can make a tree.......
and only Chevrolet can make a LUV !
Users browsing this forum: No registered users and 54 guests
