It is currently Sat Apr 04, 2026 1:05 am
 Post subject: cooling question for v8
PostPosted: Thu May 06, 2004 10:17 am
When I bought my v8 Luv it had two 4 cyl mustang radiators soldered together and a flexfan. I ditched the radiators and got an aluminum one from Summit. Now Im trying to decide if I want to run two small electric fans or one big one. I was thinking two would cover a greater area than one. Some of you v8 guys got any input and what youve done?
PostPosted: Thu May 06, 2004 10:55 am
I have 1 fan in my truck (a 16") Running 2 isn't a bad idea. If one fails, you have some kind of cooling with the other. You can wire one direct and the other to a temp switch to come on when it's needed.
PostPosted: Fri May 07, 2004 5:32 am
im going to start out with just one on mine just because it is all I have.
if it doesn't cool well I will be changing to two, or a bigger fan.
let us know what you do and how it turns out.
thanks
03Cobra
PostPosted: Fri May 07, 2004 9:21 am
Thanks for the input. I like that idea of using two and putting one on a temp. switch. Great idea. Even if it never comes on Ill always have it there for peice of mind.
PostPosted: Fri May 07, 2004 12:10 pm
The second fan Will kick in. Trust me.
PostPosted: Fri May 07, 2004 3:01 pm
I have 1 big one on mine. I've never had a problem with it. My 12 hour trip home with the truck when I bought it at 3500 rpm's, it got a little warmer than I liked but never got hot.
 Post subject: Cooling
PostPosted: Fri May 07, 2004 9:03 pm
What is considered HOT?
I've got an old Howe alum radiator now that is pretty beat with two 11" fans. Seems ok, typically gets about 170-180 and stays there, as long as I don't get stuck in heavy traffic anyway. I have a 160 thermostat.
What is the lowest temp thermostat you can get?
PostPosted: Fri May 07, 2004 9:15 pm
My Buick V-6 had a 160 thermostat in it and it would read 170-180. It could be that the gage is reading a little high. At least thats what i thought was happening with the Buick. I dont think you want to go lower on the thermostat. There is such a thing as running too cool. I'm looking in to buying a new multi-meter because the old, cheap one i had took a dump. The kind i want to get will also take a temperature reading as well using a probe. This way i can get a more accurate temp reading and compare it to the gage reading.
PostPosted: Sat May 08, 2004 12:23 am
i am using a stock radiator on my v6 and it runs at about 180 when in town and about 195 when i do my paper route....but she idles a lot then too.
