It is currently Sun Feb 01, 2026 5:11 pm
 Post subject: Car shut off on freeway
PostPosted: Tue May 04, 2004 2:00 pm
Well today while driving home from work, the radio cut off, I did not think anything of it, when I got off of the freeway the car shut off and it wouldnt stay started unless I had my foot on the gas, does anyone have any suggestions. My car is a 1978 chevy Nova. Thanks Shane
PostPosted: Tue May 04, 2004 2:19 pm
I personally would think it would be a fuse in the fuse panel or a fusible link somewhere.......
PostPosted: Tue May 04, 2004 2:36 pm
Thats what I was thinking but I checked all the fuses and none were blown, I dont even know where to look for the fusible links at. Shane
PostPosted: Tue May 04, 2004 3:50 pm
Usually it looks like a fuse wire would on like a stereo harness usually there is one one the positive cable.
PostPosted: Wed May 05, 2004 3:23 pm
your ignition switch could be going bad that would cause the radio to cut out and all sorts of other weird things to happen
PostPosted: Wed May 05, 2004 3:30 pm
That is also true as well if switch is developing a bad contact can cause all kinds of thing just like racelife said.....
PostPosted: Wed May 05, 2004 4:25 pm
Ok, I found out today that the radio doesnt work at all, everything else electrical works and so does the alternator, I tested all of the fuses and they all work too, so I guess the only thing left would be the ignition switch. I am still open for more suggestions though. Thanks, Shane
PostPosted: Wed May 05, 2004 4:38 pm
Would it be the ignition switch itself that I buy, or the ignition lock cylinder. Shane
PostPosted: Wed May 05, 2004 6:23 pm
the switch....ya nut! 8)
PostPosted: Wed May 05, 2004 9:25 pm
I know, sometimes I feel like a nut sometimes I dont :oops:, hey chevyluvguy did you win that luv on ebay.
PostPosted: Thu May 06, 2004 4:25 am
If its not the switch, clean the batt posts. I had that prob with one of my Jettas. If you have a low power alt, it may have to have it floored to keep enough power to run it. But if its not getting enough power unless you keep it floored, give it a bigger alt, and check the batt.
