It is currently Sun Jun 07, 2026 1:12 pm
$200 4x4, bad bottom end
good deal 75%  75%  [ 3 ]
bad deal 25%  25%  [ 1 ]
Total votes : 4
 Post subject: G180 VS G200
PostPosted: Mon May 03, 2004 10:48 am
whats the difference and are they interchangable??????
PostPosted: Mon May 03, 2004 12:37 pm
I personally I would take it you never knwo what could be done with it what parts could be used on other trucks :D
PostPosted: Mon May 03, 2004 2:15 pm
well, actually i was trying to figure out if a g180 bottom end will fit a g200 top end.
i was wanting to fix it for my wife.
PostPosted: Mon May 03, 2004 2:19 pm
Oh ok I wish my wife would let me build her one she wont let me :cry:
PostPosted: Mon May 03, 2004 7:29 pm
Luvtruck.com Wookie
if the manifolds look the same the worst you would have to do is bore up a little to make sure the compression is right.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Mon May 03, 2004 10:20 pm
ok.....brain cramp :oops:
the early luv motors were not the same as the later 70's... :oops:
got a 75 bottom end and a 78 or 79 top end.......they won't work will they??????????????????????? :oops: :oops: :oops: :oops:
PostPosted: Tue May 04, 2004 1:00 pm
75 and older LUV motors are not at all compatible with 76 and newer G180s and G200s. The block and head designs are completely different. I doubt you'd find two bolt holes that would line up. You'd need a 180 from 76 or newer to match any G200 parts.
If I recall the G200 and later G180 are pretty much interchangable. There might be a slight difference between the size of the combustion chamber on the head, but its not enough to cause much problem if you put a 180 head on a 200 or vice versa. Hopefully Kuranosuke will notice this thread and give some details. I know he looked that very problem over in some detail when he built up the motor for his LUV. See his thread here:
http://forums.luvtruck.com/viewtopic.ph ... sc&start=0
Users browsing this forum: Baidu [Spider] and 29 guests
