It is currently Mon Mar 23, 2026 10:31 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: makin a tube rear bumper
PostPosted: Sat Apr 17, 2004 8:39 pm
well i dont have pics yet i ll post tomorrow i am almost done i hope it turns out all right
here is what it will kind of resemble
__________ _________
|__tube____| |__tube___ |
______________ _____________
|__tube________| _ _ _ _ _ _ _ |___tube______|
|_________________________________|
ahh heck i ll just take a pic of it to hard to explain
PostPosted: Sat Apr 17, 2004 9:44 pm
If anyone wants to see what the spacing on that drawing is supposed to look like, click the quote button in jk's post. It will show up correctly in the edit box once quoted.
It looks sort of like one I've got 3/4 built. Last time I saw it though was about 5 years ago, I think its hiding in the back of the barn on the family farm. It has a solid tube across the bottom, then two tubes across the top with stubs of tube hooking them together. I was always going to rework it so that it had better center support and a reciever for a hitch, but never got around to it. Good to hear you're getting further in your quest for a LUV tube bumper than I managed to. ;)
PostPosted: Mon Apr 19, 2004 2:22 pm
You sure wern't kidding 800!
PostPosted: Mon Apr 19, 2004 8:50 pm
ok its almost done gotta make a reciever hitch and spruce it up i am gonna have it powder coated then put chrome plugs on ends of the pipe
thats the back side where it mounts
this is the front
this is the side view
i ll take some better pics next time not enough light
PostPosted: Tue Apr 20, 2004 7:02 am
should look great when your done post some pics when it is done and on the truck ........might need one for my truck......once it gets fixed anyways...
PostPosted: Tue Apr 20, 2004 7:24 am
lookin great man :D
it's cool cause know you can say you custom made that 8)
PostPosted: Thu Apr 22, 2004 9:57 pm
well tomorrow i ll have pics of the other stuff i added cause the rect tube on the bottom seemed to plain
so i got some ideas and i almost got the reciever hitch on their then i am going to recess the bottom tube for led lighting two lights
i also need to find some 2" chrome dome shaped plugs for the pipe so tomorrow
PostPosted: Mon Apr 26, 2004 8:03 pm
not done yet gettin closer
needs the reciever tube in and then sanded down with 100grit for powder coating
i am happy tomorrow i get a pacesetter header for my luv and later will put a flowmaster muffler on then i ll get the electronic ignition
but next thing i buy is a couple of subs and amp and the works
PostPosted: Mon Apr 26, 2004 8:31 pm
man that looks sick i definatly wanna c it when it is done
do you believe in LUV at first sight or does one have to drive by you again?
76' stepside mikado w/sunroof
PostPosted: Mon Apr 26, 2004 8:35 pm
Looks great!! :!:
77 2wd - Back on the road
05 Ford Five Hundred
PostPosted: Mon Apr 26, 2004 10:18 pm
Lookin good jk, are you gonna build a roll bar next??
PostPosted: Tue Apr 27, 2004 1:42 am
yah i got the material for it except i am thinkin of having speakers in the back of my bed and port through the cab so
i kinda want a bed cap and roll bars at same time
we just got an 8' sheet metal brake so i could make a bed cover
except sheet metal would be expensive 8O i dont know i ll post other things i am buildin when i get to them
but thanks for the compliments this site inspires me to fix the luv up
PostPosted: Tue Apr 27, 2004 6:55 am
Looks great jk....How much would you charge me to make me one for my truck....
PostPosted: Tue Apr 27, 2004 7:21 am
that looks good, but you just screwed your departure angle.... :(
03Cobra
PostPosted: Tue Apr 27, 2004 8:26 am
:?: hows that
PostPosted: Tue Apr 27, 2004 8:47 am
well i am gonna powder coat it which the guy said was bout 30-40 dollars
and material be about 40-50 dollars
it weighs about 35lbs or so
and then labor which i havnt figured out to be i am still not finished
but i dont know if i would build another :?:
PostPosted: Tue Apr 27, 2004 9:06 am
Alright well let me know I dont have a welder to be able to make it but would like to have one. Just dont like the price they want for one thats already built....
PostPosted: Tue Apr 27, 2004 9:46 am
:?: hows that
cause when you come off of a hill and the front gets on level ground the rear will hit at a lesser angle now....causing the rear wheels to come off the ground in some cases....
I guess it depends on if you take it off road much.
and from the good looks of the truck I take it you dont?
:D
03Cobra
PostPosted: Tue Apr 27, 2004 12:29 pm
looks good, but personally i think you should've cut a hole in the square tube piece below the round tubes and put the receiver in there. would've looked a bit cleaner and give you a little more departure angle. you'd just have to get a bigger drop hitch
PostPosted: Tue Apr 27, 2004 6:37 pm
its funny you mentioned that cause i am taking the 3" flatbar off the bottom cause i will have to make a lot more support and i dont want that drop like you said either just more problems i am still going to put led lights and recess them in that tube
oh i have i and rolled my truck :) tuff as a nail
i have made it through some amazing stuff with passanger tires
thats why i am building this up for the mud for next fall i hope it gets done
before then
thanks for your input guys
