It is currently Sun Jun 07, 2026 5:12 pm
 Post subject: pitman arm...
PostPosted: Fri Apr 02, 2004 10:56 pm
ok im trying to remove a steering box from a 72 luv. Well im at the part where i gotta get the pitman arm off the steering box. I rented a pitman arm pull and after getting the nut off the arm i placed the puller on there and started tightening in order to pull it off....welll after about 2 turns i realized it was not going ANYWHERE anytime soon. So guys, is there some kind of weird retainer on this thing that I am missing somehow? Or is it just stuck really freakin hard?
PostPosted: Fri Apr 02, 2004 11:49 pm
Just stuck freaking hard. When I changed the steering gear box in mine a few years ago, the old pitman arm on the good box I got from the junkyard had to be cut off with a acetylene torch.
PostPosted: Sat Apr 03, 2004 6:40 am
i say attack it with a hammer! :lol: :lol:
....but thats just me
PostPosted: Sat Apr 03, 2004 9:27 am
NOYZ
The torch came after the big f------ hammer couldn't hack it.
PostPosted: Sat Apr 03, 2004 1:23 pm
use the puller and as you are tightening it hit the end of the puller with a bfhammer. they are just realley tight. i can do one in the rig.
good luck....and happy hammering 8)
PostPosted: Sat Apr 03, 2004 2:08 pm
thx guys, got it off finally. I actually put a heat torch to the pitman arm to make it expand a bit and pull off the shaft coming out of the steering box a little bit easier...
PostPosted: Sat Apr 03, 2004 10:30 pm
you just wernt hitting it hard enough! :lol:
PostPosted: Sun Apr 04, 2004 4:25 pm
for some reason the luvs pitman arm seems harder to remove than most. i've removed mine several times and it takes a torch everytime. after breaking a pitman arm puller while using a big hammer, i don't mess with the hammer any more and go straight for the torch.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Tue Apr 06, 2004 6:23 pm
I couldnt get mine off.... but im goin to power steering now, usin a box from a monte carlo... so I aitn worried bout it now.
