It is currently Sun Jun 07, 2026 12:16 pm
 Post subject: where the hell is that?
PostPosted: Tue Mar 30, 2004 1:21 am
hey where is the temp sensor on the engine i cant find mine anywhere and the damn book dont say where it is either (well at least that i can find)
1-2 it's not new, 3-4 shave the door, 5-6 learn some trix, 7-8 make it scrape!, 9-10 show your friend!
PostPosted: Tue Mar 30, 2004 1:26 am
If I remeber right.. I think it is on the bottome of the intake... not sure.. haven't messed with a stock motor in a while... should get several replys in the morn..
PostPosted: Tue Mar 30, 2004 3:05 am
bottom of intake
PostPosted: Tue Mar 30, 2004 8:03 am
second that....under intake front side
PostPosted: Tue Mar 30, 2004 7:06 pm
find a wire that runs to the under side of the intake, this should lead you to your temp sender.
 Post subject: swaped wires
PostPosted: Tue Mar 30, 2004 7:10 pm
Don't do what I did. I swapd the wires on the temp and oil sensor. My temp guage would first come on all the way to hot and then back to cold. and the oil guage slowlyg got brighter. :lol:
PostPosted: Tue Mar 30, 2004 8:19 pm
when i put my motor back in last weekend i did that. It scared the crap out of me. I start it hop out time it and jump back in for a quick lap around the block and the temp gage is pegged at hot and my oil light is on bright. :lol:
PostPosted: Thu Apr 08, 2004 12:56 am
The temp sender is almost directly under the thermostat housing on the under side of the intake manifold. When you are feeling around under there, it kind of feels like the end of a bolt or something so it is a bit hard to find. If you find something sticking out straight down below the thermostat though, you probably have the right thing.
