It is currently Sun Jun 07, 2026 1:06 pm
 Post subject: Luv Instrument Cluster
PostPosted: Wed Mar 24, 2004 4:47 pm
Do they interchange as long as they are the same style? Basically, is the circuitry all the same? I am lookin for a new cluster for my 79 and i found one from a 78.
PostPosted: Wed Mar 24, 2004 6:55 pm
yea they should swap there's probably a difference in 2wd and 4wd because of the 4wd light. so if you have 4wd look for one out of a 4x4 or 2wd if you have 2wd.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Wed Mar 24, 2004 6:57 pm
YUP.
PostPosted: Wed Mar 24, 2004 9:01 pm
thats strange...i have a 4x4 but my current cluster doesnt have a 4wd light...where is it supposed to be at?
PostPosted: Thu Mar 25, 2004 5:52 am
my cluster had a 4X4 light and it is a 2WD.......
03Cobra
PostPosted: Thu Mar 25, 2004 7:44 pm
i think nate and luv4mes clusters were swapped in an accident in the factory :lol:
As far as the 4x4 light, it should be right under the fuel gage between the OIL and GEN warning lights. I realy dont think the clusters are diferent except that one light.
PostPosted: Fri Mar 26, 2004 4:54 pm
79 4x4s didn't have the light. 80s did. I have two 79s and two 80s, both 80s have a light and both 79s do not. Just another one of those little quirks I guess.
A 78 guage cluster will at least be the same style as 79 or 80. 77 and older had a bit different style guage shape and texture. pre 75 might have a couple more differences but I haven't got one of them in my flock yet. As for wiring, I'm not certain but I believe the connector pinout is the same. I think you could even swap an older 77 style guage into a newer truck without rewiring, but I've never tried it.
PostPosted: Sat Mar 27, 2004 12:02 am
Will the speedometer cable off a turbo 350 fit to the back of a stock luv gauge? Or will the stock speedometer cable fit to the t-350??
PostPosted: Mon Mar 29, 2004 11:31 pm
Now that is a toughie. I want to say yes, but I would have to see a picture cause some of those cables are square and others are trianglular.
PostPosted: Tue Mar 30, 2004 12:34 am
Tried that on my first v8 luv. it worked with one tiny problem... at about 5 mph the speedo read @30 at 25-30 mph the speedo was pegged at 85.
Resident lurker
PostPosted: Tue Mar 30, 2004 1:09 am
that would be awsome. I can see the passenger now, "wow this thing rides realy well for 85" :lol:
PostPosted: Tue Mar 30, 2004 8:14 am
mine read 50 @ 15 and they could not figure out why i was going so slow.... i told em it was new and i did not want to break it :fist:
Users browsing this forum: Bing [Bot] and 20 guests
