It is currently Mon May 25, 2026 11:05 am
 Post subject: exhaust system
PostPosted: Fri Mar 26, 2004 7:08 pm
i own a 79 luv and i really want to put an exhaust system on it. the only problem is i dont know were to find one at! does anyone know were i could find one if so please give me a web addresss or something please!! thanks
PostPosted: Fri Mar 26, 2004 11:13 pm
i made mine, it really wasnt that hard, it was a whole lot easier on the lift at school though. it comes down from the collector, comes back, makes a turn across the trans crossmember, goes under the driveline, turns again and goes over the next cross member, and then to the muffler.
PostPosted: Mon Mar 29, 2004 7:05 am
any muffler shop should be able to custom make you an exhaust system.
don't go too large diameter. those 4 cylinders need some back pressure.
pick your muffler wisely because it might be annoying at the noise they can make.
03Cobra
