It is currently Sun Jun 07, 2026 4:52 pm
PostPosted: Wed Mar 24, 2004 12:13 pm
Luvtruck.com Wookie
oil pressure idiot light...... truck's been over heating(slightly) in high load conditions the last week or two and now the idiot light for oil press. is coming on below 1200 rpm. Mains?......... oil pump ..... dunno.... i guess a rebuild is in order though since iv'e got a new head on the damn thing already.is this block(1.8) really worth keeping ? or is a 231 conversion in order.....ive got a week off. anybody with a clue how to install a 231 buick motor could really help me make the decision.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Wed Mar 24, 2004 1:40 pm
if autofab still made kits it would be much easier.
that is what I used.
03Cobra
PostPosted: Wed Mar 24, 2004 1:56 pm
Whichever is cheaper. If you have to rebuild the engine - it might cost you $400, and an engine (good and used) could cost you the same.
PostPosted: Wed Mar 24, 2004 3:07 pm
Luvtruck.com Wookie
i was wondering more along the lines of this being a work truck,i haul alot of lumber around and was thinking about being able to get a little more torgue outta this thing.would the stock 3.8 have the juice or would i be better off rebuilding the 1.8 and getting an exaust and intake setup for it. there's a million broke down olds and buicks where i live. Also im concerened about the hassle factor getting the 3.8 ready to run as a daily.
sorry... i guess i should be a little more pacific when i ask for info i guess... i dont think miss cleo is a member here eh?
TiLtEd wrote:
Boobies!!! :D
PostPosted: Thu Mar 25, 2004 5:48 am
the 3.8 has more power, is definitely more reliable and you can find parts for it out of alot of buicks.
my opinion is to do the swap. I had a 3.8 in my truck for about 8 years and never had any problems out of it.
03Cobra
PostPosted: Thu Mar 25, 2004 7:28 am
Do the swap...mho 8)
Resident lurker
PostPosted: Thu Mar 25, 2004 7:49 pm
since your working the truck hard i would do the swap as well.
PostPosted: Thu Mar 25, 2004 10:50 pm
Take a look at the V-8 swap article in the information section of the site. It's basicly the same thing but with different motor mounts.
PostPosted: Fri Mar 26, 2004 7:24 am
you could also use the v-8 swap set up to put a 4.3L in the damn thing.
just make sure you get a decent motor, and don't get anything newer than 94 or you can't use the edelbrock 4 barrel intake. :(
when i did mine i had carb at first, then because i did not check the motor i ended up replacing it 3 months later. now i have throttle body fuel injection and 235 hp :D :D :D :D
PostPosted: Fri Mar 26, 2004 3:46 pm
Luvtruck.com Wookie
well..... first of thanks for the opinions on the matter ! second yall've been pretty helpfull on the matter so i'll ofer a BIG HUGE THANK YOU! one question.
should i rebuild the buick motor before i install it? I've had 4 cars with this motor before and they all smoked,they still ran great though. all four had top end (valve seals)issues
TiLtEd wrote:
Boobies!!! :D
PostPosted: Fri Mar 26, 2004 8:48 pm
I would, but when I do stuff like that, I like to have everything good to go. That way I don't have to be worried about it. And maybe save some time pulling it back out to fix something I could've done before it went in.
Resident lurker
Users browsing this forum: Bing [Bot] and 36 guests
