It is currently Sun Jun 28, 2026 9:52 pm
PostPosted: Fri Jun 07, 2002 12:43 pm
Howard, Michael, Mike and Ben,
Could you tell me what the wheel and tire combos are that you have on your trucks. I'm trying to determine what size & I really like how your's look and perform.
Thanks,
Mike
PostPosted: Fri Jun 07, 2002 6:46 pm
Rears are 26.0/10.0 ETDrag Slicks on 15x8 rims for racing, or 265/50R15 BFG's on 15x8 rims for street driving.
Fronts are 225/50R15 BFG's on 15x7 rims.
If at first you don't succeed, try it like your wife told you to do it.
PostPosted: Fri Jun 07, 2002 9:46 pm
I run 28X11.50X15 ET Streets on a 15X8 with 5 1/2 inch backspacing. You can also use a 275/60/15 tire with the same wheel. My rearend is real close to sock length. The fronts are 165/15 on a 15X3 1/2 wheel.
Mike & Chanin Saiki
http://www.motivational.net
 Post subject: tires
PostPosted: Fri Jun 07, 2002 10:05 pm
I run a 28x12.50x15 ETstreets on centerline autodrags 15x10 wide and in front i run 165x15 on 15x3.5centerline autodrags 6 lug the rear end in my truck is a 9" thats 48"wide so i can run that big a tire hope this helps you
PostPosted: Fri Jun 07, 2002 10:38 pm
Thanks for the info. I appreciate it.
Mike :D
 Post subject: tire
PostPosted: Tue Jun 11, 2002 2:16 pm
I use a 15x3.5 Weld Drag lite in front with a 145/15 (short and skinny) but used a 165/15 before (skinny and taller)
for the rear I use a 15x8 Weld Drag lite on a 4.5" rear spacing. and a 28x10.5 goodyear eagle slick. I dont remember the width of the rear but its a 9" custom cut for the truck. Oh and some lowering blocks to put the right stance on it.
