It is currently Sun Jun 07, 2026 1:08 pm
 Post subject: MAYDAY!!!
PostPosted: Fri Mar 19, 2004 10:50 pm
My Cluch pedel assy is breaking apart and I cant find a replacement one Localy.. Its is for my 78 .. Someone pls help me.. I dont want to have to junk it just for a pedel... :( :( :(
PostPosted: Fri Mar 19, 2004 11:41 pm
Anderson....what state? CA? try couple of the wrecking yards in Redding.
Resident lurker
PostPosted: Fri Mar 19, 2004 11:45 pm
My local Chevy dealer ordered one for me about a month ago. It came from the factory. I got it in less than a week. I posted the part number for my '80 LUV in this forum.
PostPosted: Fri Mar 19, 2004 11:55 pm
That reminds me... When you do get a new one, you might want to reinforce it. There are quite a few posts on it.
thanks Robert for the mental nudge!
Resident lurker
PostPosted: Sat Mar 20, 2004 11:17 am
He's right. It was bed time last night when I posted before, and I was tired. Run bead welds down the sides and around the top of the standoff the clutch pedal swivels from to reinforce the spot welds. Plus I got small piece welded across the bottom of the standoff and welded to the bottom edge of the main bracket to eliminate twisting. But don't let it intrude past that inner edge into the inside of the bracket. Otherwise you'll play hell getting the brake pedal rehung inside. My old bracket cracked because of twisting.
PostPosted: Sat Mar 20, 2004 6:52 pm
Thanks for the info.. I shall try my local dealer agian.. last time he said it was no longer avl (last fridays when I checked) ... And I running out of luck other wise :( :(
PostPosted: Mon Mar 22, 2004 10:51 pm
Does the Break houseing come with the chuch pedel assy??
PostPosted: Tue Mar 23, 2004 12:47 am
The brake arm swings from the same bracket as the clutch swings from on my 80 LUV. It's a stamped out "U" channel with the brake in the middle and the clutch attached to the left side.
