It is currently Tue Feb 03, 2026 6:35 pm
PostPosted: Mon Mar 15, 2004 6:27 pm
all right, i put my motor in and i bought a set of block hugger headers and they don't go on. the collector hits the cross member and the flange is about 3/8 of an inch fronm sitting flush on the head. what do i need to do and has anyone else run into this problem? can the headers be bent a little to fit flush or maybe something else. help!
PostPosted: Wed Mar 17, 2004 6:58 pm
hey does anyone know if 82-92 camaro shorty headers will work. i can get a set cheap and they look like they would because they dump out in back. any response helpful.
PostPosted: Wed Mar 17, 2004 8:38 pm
Maybe some S10 V8 headers. They dump out the back too. JEGS has them pretty cheap I think, or summit.
http://www.jegs.com
http://www.summitracing.com
No LUV anymore, but still in the GM truck family. Running a lifted 2002 Silverado Z-71!
 Post subject: Headers
PostPosted: Wed Mar 17, 2004 9:30 pm
Ben has a Chevy V8 Luv truck install on the site here and I think they used Hooker headers and motormounts.
PostPosted: Thu Mar 18, 2004 6:51 am
sanderson makes shortie headers that dump out the back. I used some on a 4x4 S-10 blazer I put a V8 in.
03Cobra
 Post subject: headers
PostPosted: Thu Mar 18, 2004 8:50 pm
Sanderson makes many block hugger styles. call and get their brochure it has all their measurements so you can make a wise decision. i personally am using their CC3's. bryan
PostPosted: Thu Mar 18, 2004 11:00 pm
I run Patriot Tight Tuck Headers which I purchased from JEGS, though the way I have my motor mounted is kind of unusual. In mounting my 350 I chopped the rear lip off of the original frame mounts and added 1.25" of steel plate to the front lip. In doing this, on my truck, the headers clear any obstruction by 1/8". Here is the site for the Tight Tucks.... http://www.jegs.com/cgi-bin/ncommerce3/ ... rmenbr=361
PostPosted: Thu Mar 18, 2004 11:13 pm
Bryan, I would like to take a look at the headers in Your truck. I have got rid of torsion bars almost coilover finished.My problem is I'm running Mustang II rack, it mounts to the bolt in crossmember. I work in Woodinville for Fitz Auto. Get back to me
Users browsing this forum: Google [Bot] and 18 guests
