It is currently Sun Jun 07, 2026 9:51 pm
 Post subject: Rear spring bushings
PostPosted: Mon Mar 15, 2004 8:41 pm
where cna I get soem replacment bushings for my rear leafs? im squeekin purty back back dar.
PostPosted: Mon Mar 15, 2004 11:13 pm
I'd try Napa, they seem to have or kind find stuff for these buggars.
Resident lurker
PostPosted: Mon Mar 15, 2004 11:53 pm
http://www.independent4x.com had them in poly for my 86 Trooper and they looked like a dead on match for the set I had recently pulled off my 79 4x4 LUV. Email them and see what they say, Matt (the owner) really seems to know his stuff and will probably know for certain if they match. I was pretty sure they looked the same size, but the set I pulled off my LUV were pretty well shot so it was hard to be sure. 84-86 Trooper should all be the same, and are more likely to match than 87 and newer.
That got me 1/2 inch of lift back in the rear of the trooper, a lot less rear end "wiggle", and no squeaks. My LUV I used recycled bushings from a 2WD luv, but if I were doing it again I'd order the poly set.
PostPosted: Mon Mar 15, 2004 11:57 pm
Forgot to mention, http://www.rockauto.com also lists a MOOG set in rubber. On http://www.independent4x.com look under polyurethane or lift parts. You can get the full set (shackle and front spring hanger) or just the shackle bushings. I bought the whole set, but have yet to install the hanger bushings. They don't tend to wear out nearly so bad as the shackles.
PostPosted: Fri Mar 19, 2004 6:27 pm
ive also heard somepalce tha tnissan's are close?
Users browsing this forum: Google [Bot] and 58 guests
