It is currently Sun Jun 07, 2026 7:10 pm
PostPosted: Sat Mar 13, 2004 8:13 pm
i need the clutch and brake assembly for a 76 luv if anyone has this part or know where i can get it let me know i have checked all around here and i cant find one,i was also wondering if anythign else would work,like an s-10 or something.anyu help would be appreciated.thanks.
PostPosted: Sat Mar 13, 2004 10:35 pm
Are you asking about what's under the hood or what's under the dash?
PostPosted: Sun Mar 14, 2004 10:09 am
whats under the dash.
PostPosted: Sun Mar 14, 2004 1:48 pm
You talking about the bracket the pedals swing from? That thing breaks frequently in LUV's.
PostPosted: Sun Mar 14, 2004 2:50 pm
yeah i figured that one out my self :) but im looking for a replacement i welded mine ince but it doesnt seem to help it any it just fracturwes somewhewre else,i cant find anythin for my truck around here,not so much as even a truck around here thats worth anything,if you know of a place to order them or so,methign let me know,i really need one.thanks
PostPosted: Sun Mar 14, 2004 4:06 pm
Go back to this topic I started. Clutch/Brake pedal arm mount bracket. Good info there. I'm just finishing installing a new bracket I ordered from the local Chevy dealer. Got it in less than a week. The welds are spot, so you might want to run a bead. Expecially around the standoff that the clutch hangs from. I even got a piece welded between the standoff and the main bracket at the bottom to keep it from twisting. Plus a piece re-inforcing the the side right aft of the standoff. Thats where mine split. The part number is 094027039.
PostPosted: Sun Mar 14, 2004 4:20 pm
mine is killed the assembly and all i done tried welding it already i need the whole thing but thanks for the help though.
PostPosted: Sun Mar 14, 2004 5:59 pm
When you get your new Clutch assembly, reinforce it, as Robertcda has said. These things are a ***** to get out of there, and keep replacing. Some guys have replaced these a few times now, then they reinforced it and its all good. Just a crappy design, but nothing a bit of welding and fabricating can't improve. :)
PostPosted: Sun Mar 14, 2004 6:37 pm
Forgot to mention that the bracket costs $70. In case I wasn't clear, when I was writing about welding the bracket, I meant the new one.
