It is currently Mon May 25, 2026 10:45 am
 Post subject: Rain channel filler
PostPosted: Tue Nov 12, 2002 2:00 pm
Im looking for some kind of putty filler that i can lay into the rain channel above the doors. My channels are somewhat exsposed after getting rid of the rust. There was some kind of filler in them to keep the rain from getting into the seam. I dont think silicone would hold up. This stuff looked like bondo but not as hard. Any ideas?
 Post subject: body sealer
PostPosted: Tue Nov 12, 2002 4:08 pm
3M makes a joint and seam sealer, check with companies that sell car painting supplies, they should be able to get it.
PostPosted: Tue Nov 12, 2002 11:07 pm
i was thinking of cutting mine off ,just cut a little at a time then weld behind your cut then grind it ,fill with bondo and paint , i think it would look cool,a cleaner look! 8) p.s. that gutter holds the roof on the truck so only go 3 or 4 inches at a time!
PostPosted: Wed Nov 13, 2002 11:13 am
4linkluv took my idea.......
03Cobra
PostPosted: Wed Nov 13, 2002 5:44 pm
That's whats happening to mine in the future! SMOOOOOOOTH!! Unless I can't find any new door rubber! :D
PostPosted: Wed Nov 13, 2002 9:37 pm
i was thinkin about this today,
i think it WILL look sweet, but you need to be very carefull welding it like that as not to warp the roof.
what i would do is start on say the front driver side, cut about 3" TACK WELD (w/ mig of course :D ) then move to the pass. side rear do the same. then on to the pass. side front, then the driver side rear.
keep following this pattern till all is removed and you have plenty of good strong tacks in place,
the follow the same pattern w/ about 2" stitch welds till you have a solid seam.
my .02 :D
hell i may try it some day too
PostPosted: Wed Nov 13, 2002 9:40 pm
i put the trooper rubber in mine man it works pretty good, i pulled mine outta the junkyard but you might wanna check and see if you can get it new
