It is currently Sun Jun 07, 2026 8:03 am
 Post subject: headder
PostPosted: Mon Mar 08, 2004 1:38 pm
will any headder for a luv fit on any luv motor cuz i just bought a headder off of e bay for 40 $ and ts off of a 72 luv and im goin to put it on a 80 luv and i wanna know if it will fit.
PostPosted: Mon Mar 08, 2004 1:52 pm
72 engine is different from an 80 engine..... :(
sorry to be the bearer of bad news.
03Cobra
 Post subject: headdr
PostPosted: Mon Mar 08, 2004 8:15 pm
hey do you want to sell that hedder?
PostPosted: Mon Mar 08, 2004 9:16 pm
cowboy im gonna c if it will fit on my truck 1st just to make sure the guy i bought it from wasent wrong .. but if it does not fit i will be more than happy to sell it to ya u will have to pay shipping tho
PostPosted: Mon Mar 08, 2004 9:53 pm
the early LUV motors were a combined manifold. That meanins both the intake and exsaust are mounted on the same side using the same studs/bolts. The later years becouse of the hemi cross flow head had intake and exsaust on opposit sides.
PostPosted: Mon Mar 08, 2004 11:20 pm
i saw that header on ebay and noticed that the seller was wrong on what it would fit. it had the gaps between the 1 and 2, 3 and 4 cylinders which would be where the intake manifold would be on the early motors. the header for the newer motors is a solid piece. the flange connects from all cylenders.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Mon Mar 08, 2004 11:57 pm
so then what r u trying to say 81 4x4?? thats its not even for a chevy luv??
or that it will work on my 80 luv?
PostPosted: Tue Mar 09, 2004 9:47 am
i believe he is saying it will not fit on an 80.
If this is the hooker that was on just on ebay, it is for the early motors.
Resident lurker
PostPosted: Tue Mar 09, 2004 10:26 am
Look at the bolt pattern on the one you got. This link is to one that will fit 76-82 luvs. If it isn't the same it won't fit, unless you happpen to have an early model motor in your 80....
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33631&item=2464352222
Resident lurker
PostPosted: Tue Mar 09, 2004 6:03 pm
yea my post was a little hard to follow, that header is for the early style motor and won't fit an 80 model.
 Post subject: change in power?
PostPosted: Thu Mar 11, 2004 6:21 pm
So has anyone put this header on their 1.8L and whats the notice in power? :?:
 Post subject: header performance
PostPosted: Fri Mar 12, 2004 5:24 pm
more power , more accelleration, better gas milage. coupled with a weber 32/36 or a holley 5200, its like driving a new car!
PostPosted: Fri Mar 12, 2004 10:37 pm
i noticed better acceleration, you can hear the difference when you put it on. when you hit the gas it races up faster. i did loose some low end torque. but i had a glasspack on it. i switched to a turbo muffler and gained the torque back. the biggest difference is with the weber, it will make it go, if i could just get rid of that hesitation :evil: . the hitachi never hesitated. but overall the weber has given me alot more power.
PostPosted: Fri Mar 12, 2004 10:40 pm
look into getting your flywheel lightened, i think that helps reduce the hesitation
 Post subject: catalytic convernter
PostPosted: Tue Mar 16, 2004 4:10 pm
I think I have just a middle of the road replacement muffer on mine.
Has anyone tried puting a higher flow Cat?
PostPosted: Tue Mar 16, 2004 9:23 pm
well my truck is a federal emmisions truck so it has no cat, although i put one on it to make it burn clean enough to pass the smog test. i took it back off after it passed. if you have a cat i'd leave the cat on and put a glass pack muffler on. a glass pack has virtually no back pressure and is very free flowing, so combined with a cat would probably be about the right backpressure for the 1.8
Users browsing this forum: Bing [Bot] and 16 guests
