It is currently Sun Jun 07, 2026 11:07 am
 Post subject: Clutch question
PostPosted: Sat Mar 06, 2004 7:59 pm
:?: I am replacing the clutch on my 76 luv. Problem though...I did not notice how the discs came off. The plastic disc I heard can only fit one way but it seems to be able to fit both. On one side there is a smaller disc....does this face the motor or the tranny? Please point me in the right direction.
fullyluv :D
 Post subject: helpin ya
PostPosted: Sun Mar 07, 2004 12:15 am
there sould be a labe of some sort that says "flywheel this side" or there is a side that has a protruding edgen with springs and weights that side faces out...
PostPosted: Sun Mar 07, 2004 12:41 am
Looks like there is nothing that says flywheel...and the springs are half on one side and half on the other. There is however a side that has a small weighted disc rivited to it....so this is the side that faces the tranny??
Thanks
Ryan
