It is currently Sun Jun 07, 2026 12:23 pm
 Post subject: water problems
PostPosted: Wed Feb 25, 2004 10:53 pm
do any of u guys ever have problems with the rain leaking in the truck and on to the floor bords?? i htink its comeing fron the door jam or from the vents on the hood but im not sure so i figured id see if any 1 else have had the same problems
PostPosted: Wed Feb 25, 2004 11:45 pm
My 77 does the same thing.
I am pretty sure that it is the seal around the windshield on mine.
It could also be the door jams as well, but I think most of it is the windshield.
I will get in the truck somedays and it seems dry, until have to brake hard and water comes rushing down the back of the dash onto my feet. lol
That's why it get's the covered parking spot.
77 2wd - Back on the road
05 Ford Five Hundred
PostPosted: Thu Feb 26, 2004 12:08 am
The same thing happened on my 80, and it was coming through the widshield seal and down through the glove box.....messy
PostPosted: Thu Feb 26, 2004 12:32 am
Almost all the LUVs I've had or seen seem to leak around the windshield wiper shafts because of wear on the seals.
I posted a tip on this earlier: Leaking wiper shafts
That should cover how to fix it and give you an idea of what I'm talking about. Usually you can see cracked remains of the outer seal boots around the shafts so its not hard to spot if that it your problem. Also look under the dash for a water/dirt/rust track coming down the firewall from the shafts on the inside.
PostPosted: Thu Feb 26, 2004 1:40 am
I will have to look into that.
Excellent write up on the wipers too. Thanks!!
PostPosted: Thu Feb 26, 2004 3:00 am
my luv has holes in the floorboreds, lol :lol:
I would be vary suspect of the door seals...
PostPosted: Thu Feb 26, 2004 1:17 pm
It took me months to track the worst leak in any of my LUVs to a wiper shaft the first time. It just didn't occur to me that the two inches of standing water on the passenger floorboard could have come from something so small. I actually drilled drain holes in the floor before I finally found the leak and fixed it.
The door seals can leak a fair bit, but it is really tough for water to get inside unless it comes in while driving. From my experience the same seems to be true of leaking windshield seals. My 79 had a leak near the top of the window but would only leak after 30 minutes of highway speed driving in the rain. I cured that one with some thin silicone sealer made for windshields. Found it at Shucks I think, its high wicking so it can flow into the little cracks and crevices around the window. It goes on more like a liquid and flows into where the problem is unlike that black RTV goop.
PostPosted: Thu Feb 26, 2004 4:32 pm
my Luv doesnt leak :lol: well at lease i dont thin it does, in 2 yrs its never been out of the garage
PostPosted: Thu Feb 26, 2004 8:46 pm
take a water hose and try to find it, just go from one spot to another and look and see if its leaking in. the 76 jaguar that i used to have leaked through the vents in front of the windshield. i would check there for a leak. could be a small rust hole.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
Users browsing this forum: Baidu [Spider], Bing [Bot] and 19 guests
