It is currently Sun Jun 07, 2026 6:40 pm
PostPosted: Sat Feb 14, 2004 1:37 am
at the weirdest times my stereo cuts out...when i turn my lights on it turns off then on...same thing when i push the clutch in or put a turn signal on or flash my brights. And not ever time does it do it...sometimes when its just sittin there it turns on and off. The deck is good i know that, anybody ever have a problem like this? I dont get it cuz its wired straight up to the + on batter and a good ground...
PostPosted: Sat Feb 14, 2004 3:45 am
I was thinking it was your power supply,Maybe its your inline fuse on the stereo. Or maybe it's just haunted. lol :lol:
PostPosted: Sat Feb 14, 2004 4:40 am
check your ground
PostPosted: Sat Feb 14, 2004 9:38 am
i had that happen to me on my pioneer cd player it was a fuse under jockey box on passanger side and the fuse looked all right but i just cut that off and but connected it together and it hasnt done it since then it used to do it when i make left turns usually and then if i made a right turn it would come on again :lol:
PostPosted: Sat Feb 14, 2004 4:41 pm
Most automotive ghosts can be traced to bad grounds. Even is the deck is well grounded to the chassis somewhere in the cab, your cab may not be grounded well enough to the frame and/or engine. There should be a ground strap from the cab to the motor right at the back passenger side of the motor, and another strap from the transmission to the under side of the cab towards the rear of the trans. (Driver's side I think, but not sure)
PostPosted: Sun Feb 22, 2004 2:54 am
some radios shut off then voltage drop belove 10volts.... i hooked a system up for a boy and radio keep shuting off when he would be siting in the car playing raido with car not running.. his batery was weak to..
Users browsing this forum: Bing [Bot] and 77 guests
