It is currently Sun Jul 05, 2026 3:14 pm
 Post subject: crossmember picture
PostPosted: Thu Feb 19, 2004 9:11 pm
I took a picture of the Art Morrisson Crossmember before I painted it.
here it is.
03Cobra
PostPosted: Thu Feb 19, 2004 9:26 pm
Did it come with those frame brackets or did you have to fab them?
PostPosted: Fri Feb 20, 2004 5:46 am
I'm glad you are finally working on your truck! :D Hopefully there will be 2 Luvs running around here this summer. :wink:
stripped and just a memory!
PostPosted: Fri Feb 20, 2004 5:59 am
RAT I am shooting for early to mid spring. All my mounts are finished and painted! I am working on getting the engine together next week. I am looking for a junk set of 1 5/8" headers so I can cut some bends out of them. one of the angle plugs hits one tube on the header each side, so I have to modify them.
oh yeah....bighappy the crossmember comes with everything you need. yes that includes the frame brackets :D
03Cobra
PostPosted: Fri Feb 20, 2004 9:10 am
I went hunting for that cross member last night and came up empty. Checked Jegs,Summit, and did a basic search for Art M. Where did you get it?
PostPosted: Fri Feb 20, 2004 6:34 pm
Try http://www.artmorrison.com thats where I got my crossmember also.
PostPosted: Sat Feb 21, 2004 12:32 am
Damn it I feel retarded. I did a search using that name and nothing came up. Thanks fellas. Another part to ad to the endless pile awaiting warm weather to be installed.
PostPosted: Sat Feb 21, 2004 7:19 am
that is the trans mount xmember with exhaust clearance?
did you put it in the same location as the original trans mount?
Resident lurker
PostPosted: Mon Feb 23, 2004 5:54 am
it isn't in the same location as the stock mount. it is actually further forward than the stock Xmember. I mocked up the engine and transmission where I wanted them then located the crossmember accordingly.
yes it is the one with the exhaust clearance.
03Cobra
