It is currently Tue May 26, 2026 7:39 am
 Post subject: dropped spindles
PostPosted: Tue Oct 15, 2002 10:05 pm
hey mabey u guys can help me out now i luv my trucks 7 luvs total at the moment and the all need to be on the ground but they ride like ass so i was wondering if anyone has used a dropped spindle on a luv control arm or if an s 10 spindle will work with the luv ball joints any ideas would be great thanks
PostPosted: Wed Oct 16, 2002 8:43 pm
Hey
Just crank down the torsion bars and your set - gotta luv it!
Slap some blocks in the rear and your in the weeds.
Giles5
:D
 Post subject: spindles
PostPosted: Wed Oct 16, 2002 9:47 pm
the torsionbars are cranked and the bumps are gone and there is 3 inch blocks in the rear but i would like to ride better im considering the mustang 2 front end looks much less goofy in the long run not to mention any one considered air ride on a luv that would be cool
corvetteman43
PostPosted: Wed Oct 16, 2002 9:50 pm
You could probably fit air bags on the front if you wanted - I know you can on the rear.
I've never done it on a torsion bar type suspension but i am sure it could be done.
I know for a fact that you can on the mustang II.
Almost all lowrider mags have really good tech articals on the subject.
Giles5
PostPosted: Thu Oct 17, 2002 4:34 am
They make a air ride bolt in setup for the Mustang ll frt.end as well as coil overs.Either would give you a lot of adjustment and still keep enough travel.
I had other places I needed to put ny money so I used Pinto springs for now.I had to go back and get the with OUT air conditioining springs and I am still going to have to cut a round out of them to get the lower control arms level.
I will probably go with coil overs later as I am in the process of a 4 link and 9" at the moment.
stripped and just a memory!
PostPosted: Tue Nov 05, 2002 5:21 am
Thought I'd send you this reply from my question to Rod, but take note this is in Aussie Dollars, so it would be even cheaper for you guys as the Oz dollar is worth about .58 US at the moment. I'm waiting for a reply from Tubular Suspension Systems for a bag set-up, but I'll keep yas posted,,,,
If I was fitting a LUV with a different front end it would be the L300 Mitsubishi as drop axles are available, they are strong, take up less room, they cost less and a power rack and pinion could be used. They can be fitted with power steering and Leyland P76 discs can be fitted to get the width right down. Such a unit could be built for under $2000.00 with new discs and fitting kit, rack and pinion kit, drop axles, new bearing and seals and it would all be assembled.
Regards............Rod Hadfield
Please note, we have a new email address, it is now:
rod@rodshop.com.au
Users browsing this forum: Google [Bot] and 31 guests
