It is currently Sun Jun 07, 2026 6:02 pm
 Post subject: dual carb ?
PostPosted: Tue Feb 03, 2004 9:28 am
well i bought the dual carb dellorto in the classified a lil bit ago and was wondering what i need to change out a guy at that worked for auto repair for a while told me i would be goin through rod bearings just that it would tear stuff up so i m not puttin them on till i know what needs to be done i am goin to get a header and a new rv cam and tryin to find a high volume oil pump and water pump cause i am adding lots of stuff to this lil 4 banger i personally think itd be sweet with dual carbs so if any body has some input i ll be here to read it
Later
James
PostPosted: Tue Feb 03, 2004 12:57 pm
OG Lifer
Holy run on sentance. I tried to read that, but couldn't understand half of it.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Tue Feb 03, 2004 8:20 pm
sorry i dont like punctuation (.) but i was askin
what parts i need to change out when i put dual carbs on the stock 4 cyl
this guy i talked with worked at an auto store for 10 yrs he said i will go
through rod bearings and other parts?
so i was wondering will it effect anything else or what ?
i was planning on buying a header & rv cam gettin a new high
performance clutch by zoom and get another tranny i think this one needs
to go bye bye but any ideas on other parts sorry bout the last post i was
kinda tired.
PostPosted: Tue Feb 03, 2004 9:08 pm
i really doubt that you're gonna be blowing stuff up on a luv motor with dual carbs. that guy makes it sound like you're running a supercharger on it or something
your stock drivetrain should probably be able to handle it fine
PostPosted: Tue Feb 03, 2004 9:16 pm
I agree, I think your biggest problem will probably getting them synchronized, not blowing stuff up.
Resident lurker
PostPosted: Tue Feb 03, 2004 9:49 pm
OG Lifer
Ok, I am starting to see what you want. All you really need is to bolt the setup on, assuming it doesnt need rebuilt, and get 2 vacuum gauges. I mounted 4 gauges to a 2x4 and use it on my kz-650. Plumb the gauges into your carbs, on a vacuum port. One gauge for one carb. Then start setting the air/fuel mixtures until your carbs are pulling the same amount of vacuum. Then set your idle speeds, and recheck your vacuum readings. I am not sure how many inches the luv should pull to make it run right, and not too rich/lean.
PostPosted: Tue Feb 03, 2004 9:50 pm
i don't see how dual carbs would affect rod bearings, you're only giving it more fuel and even if it was too much fuel it wouldn't hurt the engine, it would just burn rich or flood out. the only way it could hurt it is if you run it wide open and blow it up, but that goes for any carb.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
PostPosted: Tue Feb 03, 2004 10:12 pm
the best place i found so far to get jets and other parts for the dellorto is cb performance in cali. they seem to have the best prices and availabilty. www. cbperformance.com. they mainly deal with vw stuff
PostPosted: Wed Feb 04, 2004 12:27 am
Zounds! Krikies! What a Pain! I can't get mine to work right and I see someone wanting duals!
Kinda overkill for a 4 banger unless your doing a 2 Fast 2 Furious thing.
PostPosted: Wed Feb 04, 2004 12:36 am
its an experiment if i dont like them i ll sell them basically dont get me wrong i am looking for a muscle car right now running good with a strait body and no rust under 5000 bucks nothin wrong with tinkerin on a vehicle lol
PostPosted: Wed Feb 04, 2004 9:17 am
With a header & RV cam, I think the dual carbs would be pretty cool. The trick to any engine is to make it breathe & exhale better. Putting 2 carbs on a 4 cyl isn't "2 Fast 2 Furious" stuff. They were doin' that to the Ford 4 bangers back in the '40s & '50s! :wink:
'46 Studebaker truck "project"
'90 Trooper 4X4, 2.6L 5 spd
PostPosted: Wed Feb 04, 2004 3:41 pm
just an FYI, dual carbs are at their best in mid to high range rpm, around 3500-5000. that's why they're popular in circle track racing.
and i doubt that really any of those fast and the furious guys even know what a carb is :lol:
